some of the head injections, like Emma, Samantha; aren't morphs themselves, they call a collection of head morphs.
Some of the older character injections were for V4.1; in those days, they didn't use the readscript headers to automatically inject the required morphs for you. so, if the morphs the character's inj file calls aren't already injected, you won't seem them work.
large droopy breasts?
What are a couple of those characters you're trying?
sometimes you have to open the .pz2 file to see what's going on.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
RMElaine head morph works fine body morph just produces a dial that says stomach depth (just makes stomach go in ) pics that go with the body injections show 3 increases in overall body mass B1 does nothing B2 gives stomach depth B3 does nothing. RM Mylin body injections and head work perfect produces no dials when body is selected but does show a dial (that works when you click on each body part)
I thought in poser 8 that selecting the body shows all the dials for all the parts is that not the case in poser 2010?
inside the runtime:!daz folder is a file (I am at work and poser is at home so I can't remember the exact name) that you have to run that loads all the channels into the cr2 for V4. It sounds like you need to run this first.
Gary
this will call the inject all. paste into a plain text file. name it with the extention .pz2 and save it to the Pose library.
version
number 4.01
readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:InjDeltas.V4Morphs++All.pz2"
Quote - RMElaine head morph works fine body morph just produces a dial that says stomach depth (just makes stomach go in ) pics that go with the body injections show 3 increases in overall body mass B1 does nothing B2 gives stomach depth B3 does nothing. RM Mylin body injections and head work perfect produces no dials when body is selected but does show a dial (that works when you click on each body part)
It depends how the .pz2 file is set up.
The MyLin is made of a custom head morph and body morph.
Custom Body morphs will usually show on the Body properties pallete under
+Injection Channels
+Daz
+Community -section, it's usually the last subcategory on the palette.
If we weren't talking about RM, I'd guess they forgot to put a FBM dial, but RM has been around a while.
This will unhide the BreastDroop dial.
same as the other one, paste it into a plain text file, save it as a .pz2 file and save it to librariesPose
version
number 4.01
actor BODY:1
channels
valueParm PBMBreastsDroop
hidden 0
actor chest:1
channels
targetGeom PBMBreastsDroop
hidden 0
You would need the internal name of the morph, which you can find if you open the .pz2 injection file for the particular morph under librariespose
screenshot example
A few years ago i use to use poser 8 , then stopped for a while and now have moved on to poser 2010 . I seem to remember when injecting the morphs in to v4 there was an inject all which i cant seem to find now I can inject one thing at a time but when i inject another the first one goes eg brest size , inject works ok and there is a parameter dial for breast size which works ok but if i then inject say breast droop then that dial appears but the breast size dial dissapears as does the adjustment i had made so immpossible to have large breasts and droop .If i then inject say body builder that will work but then the breast adjustments are gone , then som injections just will not work at all. Some characters i have the head injection works but not the body and some characters work as they should body and head what on earth am i doing wrong can any one help????
