Sun, Dec 1, 12:54 AM CST
Subject: victoria 4 morphs not all working
iborg64 ( ) posted Tue, 17 January 2012 at 2:53 PM · edited Sun, 01 December 2024 at 12:48 AM
A few years ago i use to use poser 8 , then stopped for a while and now have moved on to poser 2010 . I seem to remember when injecting the morphs in to v4 there was an inject all which i cant seem to find now I can inject one thing at a time but when i inject another the first one goes eg brest size , inject works ok and there is a parameter dial for breast size which works ok but if i then inject say breast droop then that dial appears but the breast size dial dissapears as does the adjustment i had made so immpossible to have large breasts and droop .If i then inject say body builder that will work but then the breast adjustments are gone , then som injections just will not work at all. Some characters i have the head injection works but not the body and some characters work as they should body and head what on earth am i doing wrong can any one help????
Eric Walters ( ) posted Tue, 17 January 2012 at 3:07 PM
 I'm not really sure. I've recently had issues with morphs vanishing-with the dial still present-but not the problems you are having. I would try with a fresh copy of V4.2-your files may be corrupted.
MistyLaraCarrara ( ) posted Tue, 17 January 2012 at 3:22 PM
some of the head injections, like Emma, Samantha; aren't morphs themselves, they call a collection of head morphs.
Some of the older character injections were for V4.1; in those days, they didn't use the readscript headers to automatically inject the required morphs for you.  so, if the morphs the character's inj file calls aren't already injected, you won't seem them work.
large droopy breasts?  😄
What are a couple of those characters you're trying?
sometimes you have to open the .pz2 file to see what's going on.
iborg64 ( ) posted Tue, 17 January 2012 at 3:38 PM
RMElaine head morph works fine body morph just produces a dial that says stomach depth (just makes stomach go in ) pics that go with the body injections show 3 increases in overall body mass B1 does nothing B2 gives stomach depth B3 does nothing. RM Mylin body injections and head work perfect produces no dials when body is selected but does show a dial (that works when you click on each body part)
I thought in poser 8 that selecting the body shows all the dials for all the parts is that not the case in poser 2010?
Plutom ( ) posted Tue, 17 January 2012 at 6:05 PM
It sounds like you are injecting one morph at a time.  There is an overall morph function that will apply all of them at once, just scan down until you find it...Jan
grichter ( ) posted Tue, 17 January 2012 at 6:46 PM
inside the runtime:!daz folder is a file (I am at work and poser is at home so I can't remember the exact name) that you have to run that loads all the channels into the cr2 for V4. It sounds like you need to run this first.
Gary
MistyLaraCarrara ( ) posted Wed, 18 January 2012 at 10:45 AM
this will call the inject all.  paste into a plain text file.  name it with the extention .pz2 and save it to the Pose library.
    version
        number 4.01
    readScript ":Runtime:libraries:!DAZ:Victoria 4:Deltas:InjDeltas.V4Morphs++All.pz2"
MistyLaraCarrara ( ) posted Wed, 18 January 2012 at 10:59 AM · edited Wed, 18 January 2012 at 11:04 AM
Quote - RMElaine head morph works fine body morph just produces a dial that says stomach depth (just makes stomach go in ) pics that go with the body injections show 3 increases in overall body mass B1 does nothing B2 gives stomach depth B3 does nothing. RM Mylin body injections and head work perfect produces no dials when body is selected but does show a dial (that works when you click on each body part)
It depends how the .pz2 file is set up.
The MyLin is made of a custom head morph and body morph.
Custom Body morphs will usually show on the Body properties pallete under
+Injection Channels
+Daz
+Community  -section, it's usually the last subcategory on the palette.
If we weren't talking about RM, I'd guess they forgot to put a FBM dial, but RM has been around a while.
MistyLaraCarrara ( ) posted Wed, 18 January 2012 at 11:03 AM
This will unhide the BreastDroop dial.
same as the other one, paste it into a plain text file, save it as a .pz2 file and save it to librariesPose
    version
        number 4.01
    actor BODY:1
    channels
        valueParm PBMBreastsDroop
            hidden 0
    actor chest:1
        channels
        targetGeom PBMBreastsDroop
            hidden 0
MistyLaraCarrara ( ) posted Wed, 18 January 2012 at 11:06 AM
you can use the above as a template to unhide dials.
You would need the internal name of the morph, which you can find if you open the .pz2 injection file for the particular morph under librariespose
screenshot example
iborg64 ( ) posted Wed, 18 January 2012 at 11:19 AM
thanks for all that I will look into it see how I get on
iborg64 ( ) posted Mon, 06 February 2012 at 7:42 AM
sorry but I have been messing around with this for a while now and getting nowhere i created text file in word pad but cant see how to change its file extension sorry for my ignorance but I am still unable to fix this
