Sat, Jan 25, 1:31 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 23 10:50 am)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Two questions regarding Blender 2.6x
jartz ( ) posted Wed, 18 January 2012 at 9:28 AM · edited Sun, 12 January 2025 at 9:50 AM
I've just now trying Blender 2.61 after spoiling myself with 2.49b (saved a copy just in case).  I have two questions:
How can I fix the focus in 2.61, so that the figure I'm working on won't cut me off when moving the mouse around it?
Is there a way that I can put textures I created into said figure (e.g.: Antonia), and how should I go about it.  A tutorial would suffice.
Thanks.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
jartz ( ) posted Wed, 18 January 2012 at 12:12 PM · edited Wed, 18 January 2012 at 12:13 PM
::footnote::
I think I got the first question down pat, I think.
You key in the letter n to get the camera setting...  Why couldn't I figure that out.
I remember one time of asking that question because the dynamic is quite different from version 2.49...
--so question number one is solved for now.  I just need to get to refresh myself with hotkeys since it's been awhile I tried the new version.
However,
I'm still pulling my head on how to put texture over a figure or object.
Any help would be appreciated.
unbroken-fighter ( ) posted Wed, 18 January 2012 at 8:40 PM
from the main tools pallete click the materials button and add a new material
then you will see the textures tab.......add new
jartz ( ) posted Wed, 18 January 2012 at 11:43 PM
I'll give that a shot.
Is there any way to view it?  When I add textures, it doesn't show on preview window.
jartz ( ) posted Thu, 19 January 2012 at 12:01 AM
Thanks,
I managed to get that figured, but I can't seem to get it to show on Preview mode.
Is there a way to do this?
Didn't mean to post a second time, since it expired on me.
jartz ( ) posted Thu, 19 January 2012 at 1:49 PM
I realize now that -- in order to get your textures in your figure, according to a YouTube tutorial, you'll have to get the figure UV mapped and all of that.  Not very easy and intuitive at all.
Was kinda wishing that it would be sorta simple.
Only time will tell.
unbroken-fighter ( ) posted Thu, 19 January 2012 at 8:57 PM
go to www.cgcookie.com and look through the tuts there, i know there are several on texturing. im not too used to 2.6 because i still use 2.49 primarily
jartz ( ) posted Fri, 20 January 2012 at 2:16 AM
Quote - i still use 2.49 primarily
That makes two of us.
Thank you so much for the link.  I'll check it out.
NanetteTredoux ( ) posted Fri, 20 January 2012 at 3:58 AM · edited Fri, 20 January 2012 at 4:00 AM
Poser figures are already UV mapped. You just need to tell Blender to use the UV mapping, this setting is in the image mapping tab in the texture context.
It took me a while to learn the new interface as well. The Blender Basics ebook was helpful, as was the course on gryllus.net.
Poser 11 Pro, Windows 10
MWMPHX ( ) posted Sun, 26 February 2012 at 4:22 PM
The shortcut for your first question is the . key on the numpad. Puts the view focus on selected.
Driftwood ( ) posted Sun, 11 March 2012 at 9:58 AM
If you're having trouble with the normal Blender Render materials DO NOT go to the Cycles engine yet!  The loading of textures and bumps and Specs with the node system is a major change in thinking.
Then again it works really well and starts making sense if you use it enough.  CGcookie and Blenderguru both have good tutorials showing the new cycles engine and the new way you put in textures.
RobynsVeil ( ) posted Sun, 22 April 2012 at 12:40 AM
Quote - If you're having trouble with the normal Blender Render materials DO NOT go to the Cycles engine yet!  The loading of textures and bumps and Specs with the node system is a major change in thinking.
So, am I to understand that in order to add back all those UV-mapped textures to, say, V4, you can't just add them in the checkered-box Textures area? When I imported V4 to Blender, in that section for each region I see a Kd.024, for example, and the preview is black. Under image it actually has the image file listed. I delete this, then add it back again... now the image displays in the preview, but in my 3D view, in Texture mode, my figure is purple/lilac. What might I be doing wrong? Also, SSS is not ticked.
Metaphor of Chooks
ice-boy ( ) posted Sun, 22 April 2012 at 6:42 AM
in 2 weeks a new official blender will be out. it will have bmesh. so you get advanced knife tool and an advanced mega fantastic bevel which is able to model round edges for low poly models. so we will get tools that are perfect for poser models. an example where to use this. for poser cloth.
on top of all Cycles the new realistic renderer is becoming moe and more complex. in 12 months Cycles will be able to render everything that Poser can render but faster. on top of all it will get SSS and volume effects.
so in 2 weeks you will be able to model everything in blender for poser. in 12 months you will be able to pose in Poser and render 100% realistic images with Cycles.
we are.............here ..........my friends
