Mon, Jan 20, 4:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
Subject: Clothing Morphing Problem...Anyone can lend me a hand?
Ewers ( ) posted Sun, 22 January 2012 at 3:44 AM · edited Mon, 20 January 2025 at 4:00 PM
Okay...When it comes to shorts, trucks, Bikini tops, boots, and armor I'm pretty good at putting them on. But when it comes to bodysuits I like TOTALLY SUCK...
I have been spending HOURS trying to get these outfits to fit my characters with very little luck, can someone tell me what I am doing wrong? Anyone can point me to something I can upload to help me conform and morph clothes better?
Would be very much appreciated. Thanks for viewing.
Oh...FYI - I am using Poser 9 and these are Victoria 4.2 bodies...thanks.
RobynsVeil ( ) posted Sun, 22 January 2012 at 3:48 AM
Two words: Morphing Clothes (by Dimension 3D)
Metaphor of Chooks
JimTS ( ) posted Sun, 22 January 2012 at 3:55 AM
or the PhilC's V4 add on for Wardrobe Wizard
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
PhilC ( ) posted Sun, 22 January 2012 at 5:36 AM
You already have Wardrobe Wizard in Poser 9, you just need the V4 support files.
http://www.philc.net/store_WW_Extra_Figs.php
bagginsbill ( ) posted Sun, 22 January 2012 at 7:25 AM
Does failure to magnetize come into play here?
hborre ( ) posted Sun, 22 January 2012 at 7:40 AM
This is what BB is referring to.
hborre ( ) posted Sun, 22 January 2012 at 7:45 AM · edited Sun, 22 January 2012 at 7:56 AM
And I am totally surprised that you spent hours trying to conform the outfits.  The simplest approach, regarding to your particular bodysuits, would be to make the body parts under the outfits invisible, and morph the outfits to the desired shapes.
Now if the V4 body morphs were custom, you would need to introduce those new morphs into the bodysuits by using either Morphing Clothes or Wardrobe Wizard.
If pokethroughs are still an issue, then your only recourse would be to render twice, first render of your entire scene with the offending problems, then second render the spot areas with the V4 skin made invisible.  Combine the two images in postwork using a layering 2D program like Photoshop, GIMP, or PSP.
Ewers ( ) posted Sun, 22 January 2012 at 2:19 PM
Okay...I'm an old fart still trying to figure out the functions of Poser 9, but thank for the advice folks it's really appreciated.
Ewers ( ) posted Sun, 22 January 2012 at 7:06 PM
Okay...found the magnets...selected it...and...nothing happened...
So now I got two question...
  1. What am I doing wrong?
2) Wardrobe Wizard...where the heck do I find it and how do I use it?
hborre ( ) posted Sun, 22 January 2012 at 7:14 PM
Page 536 in your Reference Manual.
PhilC ( ) posted Sun, 22 January 2012 at 7:33 PM
Wardrobe Wizard is at Scripts > Wardrobe Wizard
Select that and when prompted open the Python window to see the Wardrobe Wizard menu buttons. Window > Python Scripts
Click the "Convert" button then click each "?" button within the option fields for a quick explanation of what each bit does.
An over view video is available at http://www.philc.net/WW2_plugin_overview.php This was created in an earlier version but the opperation is much the same.
Help > Poser Reference Manual > Chapter 26 for full info.
To add morphs to your clothing, analyse the morphs then convert from V4, to V4 with the option to include morphs selected. This video tutorial will help on that. http://www.philc.net/WW2_FBM.php
Hope that helps.
kobaltkween ( ) posted Sun, 22 January 2012 at 8:51 PM
Just to add to your possible solutions, Poser also has a morphing tool that can help with this.  If you select the hand with the pointy finger in the Pose Room, then select the Create tab when the morphing tool window comes up, you can quickly create your own custom FBMs.  This is useful for small problems, but for larger ones, WW is probably easier.
That all said, I usually use dynamic clothes and don't have much of a problem with fits.  I find them much better for skin tight clothes, actually, because I can create real tautness.
