Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
What are your import options? Poser materials checked or no? By the way, that is not a FATAL ERROR. Fatal errors get cancelled by the OS.
What was your hot trick? Point to another version of Poser? Or overlay SkinVue Elite on her? Or did you manually turn off the bumps for each material zone?
THANKS for all answers ! :)
Of course this error is in BUMP CONVERSION RATIO in VUE 10.
I'm not pay attention to small detail when imported POSER files.
In old version my VUE default value is:
In new VUE 10 default value is:
WHY ? What for ? :(
My problem is solved. Maybe this my post be useful to others.
It should remember the last setting you use. I'm using .002. Sometimes with a "-" depending on how the content was made.
It does not seem to be ONLY a problem of bump map settings.
Look more closely at the arms or leg of V4: the bump map is not properly aligned (or, more likely, oriented) with the character.
Fantasy pictures,
free 3d models, 3d tutorials
and
seamless textures on Virtual Lands.
Vue 10 Infinite 64-bit has a new SDK just for Poser9/2012 importing.
E-on's marketing department is always ambiguous. The manual states:
Poser SDK from August 2011: This one supports PoserPro 2012. For 64-bit versions only.
Most Poser users on Renderosity have Poser 9 and 64-bit systems. So they don't have to worry about guessing. I'm using 32-bit and Poser 6. So I can't test for sure.
You didn't say which Vue 10 you plan to get. Call E-on first before buying is all I can say. Then get a second opinion from another E-on employee.
I do know that older SDKs will not make full use of Poser 9 or 2012, if at all. Lots of complaining at C3D by Vue 9 (pick a product) people upgrading from Poser 8 to 9. The new Poser 9 weight mapping is kind of a big deal.
Better than that. Download the Vue 10 Infinite PLE version and play all you want with Poser. Vue 10 Frontier needs the Import module in order to use Poser fully. And we still don't know from e-on if it supports beyond Poser 8/2010 or not. E-on loves it when customers buy products thinking they can do something with it and it turns out they can't. You can always get your money back, though. It would be great though if e-on flat out stated what their products can and can't do, instead of speaking in platitudes (yes, we can! nonsense).
So, I am very impatient, and took a chance, and happy to report, Vue 10 Frontier DOES import Poser 9 PZ3 without issue that I can find. (Win 7 64 bit machine)
Here is a figure imported and thrown on a terrain, sky and tree...obviously I am no good yet at Vue...but... ;-)
EDIT: Oh, and it started with a default bump of -0.008! :)
When I import ready file saved in POSER PRO 2012 to newest VUE 10 I have that errors as below:
Skin of V4 and even the torch have a gravelly, damaged, bad surface.
In VUE I use this options about POSER import:
For my it's a serious problem because I have a lot of POSER files which I need import to newest VUE 10.
With that big errors/bugs import from POSER Pro 2012 to VUE is very problematic.
Is anybody who have this same error in VUE ?
Is a peniciline for this weighty bug ?
Of course I finished my work in VUE 10 which is in my Gallery here:
http://www.renderosity.com/mod/gallery/index.php?image_id=2289132
but I applied 'super-personal-confidential hot-trick' with this Poser file when I imported to VUE.
Without this my 'hot-trick' all importing options always wrong worked - independently of changes in VUE options.
And independently of Poser version where I saved ready file.
File saved in Poser Pro 2012 have this same bug effect in VUE 10 as my oldie files saved in Poser Pro (oldie version signed number 7).
Because both version of POSER worked wrong with VUE 10 therefore problem is in VUE 10...probably.
