Sun, Feb 9, 7:17 AM CST
Subject: remove / delete full body morph
amstar ( ) posted Sat, 28 January 2012 at 2:23 PM · edited Sun, 09 February 2025 at 7:15 AM
Quick question, I know how to create  a full body morph, but deleting one is the problem.
When I go int hierachy editor and turn on all parameters I can see all the morphs and can delete what the full body morph under "Body", the problem is all the individual morphs for each body part remain!
The causes problems if I want to re-load different version of the same full body morph! Is there a way I can delete the entire full body morph in one go without having to delete it from each individual body part??
Thanks.
icprncss2 ( ) posted Sun, 29 January 2012 at 12:10 AM
Is this an FBM you created or are you trying to delete a stock FBM?
What figure?
What version of Poser?
lesbentley ( ) posted Sun, 29 January 2012 at 10:10 AM
Quote - Is there a way I can delete the entire full body morph in one go without having to delete it from each individual body part??
The short answer is "No".
Using a Poser library file editor (I use CR2Builder) to edit the cr2, may be easier than doing it in the Poser Hierarchy Editor, but will still be tedious if many body parts contain the morph. One or more of the commercial editors may have a feature to do it, but I don't remember hearing of such a feature.
As you want to "re-load different version of the same full body morph", an alternative solution may be to create a delta injection pose to inject the new version of the morph into the old channels.
If the figure uses PBMCC channels (most recent DAZ figures do) you can use svdl's "SpawnCharacterP6 update" to make INJ and REM files. If not you could use "Pozers Little Helper".
JAFO ( ) posted Sun, 29 January 2012 at 11:25 AM
cant you just go to 'body' level use the > button beside the  FBmorph dial and hit delete and resave the figure? ....naah it cant be that easy.
JAFO
Y'all have a great day.
WandW ( ) posted Sun, 29 January 2012 at 12:05 PM
Online Now!
I would try deleting it in MorphManager...
imax24 ( ) posted Sun, 29 January 2012 at 5:55 PM · edited Sun, 29 January 2012 at 5:55 PM
PhilC's Poser PocketKnife can delete the FBM and all associated PBM's in one swoop.
Which is handy, because even if you make one small PBM in V4's left shin, Poser generates a Custom Morph dial in all 50+ body parts, from the tips of her fingers to all of her tongue joints. I'm constantly using Pocketknife to delete all the extra Custom Morph dials.
The day Poser creates a new dial in only the parts actually morphed, I will be a happy camper.
lesbentley ( ) posted Sun, 29 January 2012 at 7:09 PM
Good to know that good ol' PhilC's Poser PocketKnife can save the day.
Quote - Which is handy, because even if you make one small PBM in V4's left shin, Poser generates a Custom Morph dial in all 50+ body parts, from the tips of her fingers to all of her tongue joints.
Hu? I have never seen that! It certainly does not happen for me in P6. What procedure are you using?
imax24 ( ) posted Sun, 29 January 2012 at 7:42 PM · edited Sun, 29 January 2012 at 7:43 PM
With the Morph Brush. In P6, P7 it only morphs the body part you touch. But starting in P8, you can paint a morph across body parts. Unfortunately it generates a Custom Morph dial in EVERY body part, more than 50 of them, even though all the extra ones don't do anything. In this regard I miss Poser 7!
lesbentley ( ) posted Sun, 29 January 2012 at 7:56 PM
Thanks for the explanation imax24.
amstar ( ) posted Mon, 30 January 2012 at 1:18 AM
Quote - I would try deleting it in MorphManager...
not sure I've actually tried this, hopefully it works
amstar ( ) posted Mon, 30 January 2012 at 1:20 AM
Quote - cant you just go to 'body' level use the > button beside the  FBmorph dial and hit delete and resave the figure? ....naah it cant be that easy.
JAFO
no, that's what I did via the hierachy editor basically... it just removes the one dial from the body, all the other across all other body parts remain!
amstar ( ) posted Mon, 30 January 2012 at 1:23 AM
Quote - Is this an FBM you created or are you trying to delete a stock FBM?
What figure?
Poser Pro 2012, yes either imported FBM or when morphing with the morphing tool, both same deal
lkendall ( ) posted Mon, 30 January 2012 at 1:50 PM
PhilC's Poser PocketKnife for those who might want these useful tools.
lmk
Probably edited for spelling, grammer, punctuation, or typos.
