If it is a shadow problem (i can't see too well on my phone) you could try raising the shadow samples. Try 50+(?)
PoserPro2014(Sr4), Win7 x64, display units set to inches.
www.danielroseartnew.weebly.com
Your shader is trying to do very small freckles and your shading rate is too high. The result is you are getting aliasing of these small features into large ones. It's not really there.
Change your render setting Min Shading Rate to .2 and see how that goes. Then work back higher to recover speed until you find a compromise you like.
Or - get a shader expert to fix the shaders.
That looks like a blurred shadow from a tree. Try raising the RT shadow samples. It may still look like a dirty shadow, but it'll be smoother. (I use shadow samples of 50 or higher)
![file_477995.jpg](https://live.cdn.renderosity.com/forum/threads/2843575/file_477995.jpg)
Ok so this new picture im working on i ran into some sort of problem. It seems that there skin has a grainy look to it. How do i fix this. could it be something in my lighting settings? (attached picture of settings) or could it be that the scene im using is casting some sort of shadow over there skin?You guys are always the best here so i figured i would ask here before i drive myself nuts lol
Thanks again!
