Forum Moderators: Staff
I don't believe this - my modem reset itself and when I logged back on to the 'Net I was able to use the camera controls properly! What's up with that?!?!?!? I seem to recall something about Poser logging on to the Internet to check if you're using a pirated version. Is this true? Would it be why my copy screwed up, cos it was checking my authenticity? Oh, incidentally, my copy is true-bill original!! Well, that's one for the "Strange" files anyway. Sorry to disturb y'all. :o)
Hi troops! Yes, it's true - ever since downloading the Sophia figure from FreeStuff my copy of Poser has been doing daft things. All the controls appear to be disabled. I can select which camera to view the figure with, but if I try to use any of the control panels to the left of my work area, all that happens is that the camera pans to the right, moving the figure off-screen. Reversing the procedure (i.e., moving the mouse the opposite direction) simply makes the camera continue panning to the right. Thinking back, I loaded the figure up and zoomed in on it. Next I applied a texture, and finally I tried to re-pose the figure's neck. After that things went daft. I don't recall locking anything, pressing any strange key combinations or anything else that may ahve caused this. Can anyone else think of what I might have done wrong? As usual, all input is appreciated, all help gratefully received! Cheers! - Hairy <=== Suffering withdrawal symptoms
