Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 18 2:02 am)
This is what me nearly made crazy, it worked and I tested it it still works at least in Poser 8. It is an old file that has a version number 3 but I believe I have it since Poser 6 as the files are from 2009.
Ulli
In that case it looks like a new bug introduced in P9
Report it to Smith Micro so they can have a look at it and maybe fix it
I understand your frustration - I have had similar experiences in the past with similar issues - such as Poser loading the wrong object because the path references were incomplete.
Well, incorrect pathes should not work but I experienced a similar thing when I got Poser 6. Before a not existing hidden statement was interpreted as "not hidden". With Poser 6 the game changed and a not existing hidden statement was interpreted as hidden 1.
I don't think it is a bug, I believe they have now stricter rules for the interpretation of commands and rules implemented.
Ulli
Accidently I found a new "feature" in PP 2012.
If you have a morphinjection outside of the pose file you have to use the readSript command. E. G. You have a pose named InjMySuperbody.pz2 and the Deltas are located in :Runtime:Libraries:Superbody you have to insert in the Pz2 file a command like:
readScript ":Runtime:Libraries:Superbody:InjMySuperbody.pz2
With Poser 5, 6, 7 and 8 no problem. It worked well but with PP 2012, and I expect also with Poser 9, nothing happens.
It took me a while until I found out, that PP 2012 doesn't like the same filenames, even when they are located in different pathes.
After renaming the file to 01InjMySuperbody.pz2 everything worked fine.
Ulli
