Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 7:49 pm)
There is a tremendous amount of information that is lacking from the OP. This is their first post and there are too many assumptions being made. As far as I can ascertain, the OP may not have conformed clothing correctly and is essentially seeing the figure move and not the clothing resulting in pokethrough.
@ makis12: you will need to provide as much thorough details as possible. Speculation will not adequately answer your questions or issues. Provide which Poser version you are using, what type of clothing you are attempt to dress you model, what is your workflow, etc. More details will help us help you quicker.
or if the part that is poking through when made invisible (chest for example) shows eg missing, you can use the editing tools morp brushes, very easy to learn (push, pull, and smooth-push and pull require a magnitude of around .o4 and smooth requires a magnitude of 1 (ONE).
A custom morph dial will be created too. Jan
Quote - There is a tremendous amount of information that is lacking from the OP. This is their first post and there are too many assumptions being made. As far as I can ascertain, the OP may not have conformed clothing correctly and is essentially seeing the figure move and not the clothing resulting in pokethrough.
This.
Hey guys,thank you all for your answers.I did what Glitterati3D said and it worked .However when i do this it fixes the part of the sleeve that i mentioned but it creates a similar problem to another part of the cloth such as the over back side of the sleeve.I f there is a way to fix that too please reply,if not thank you very much.I really appreciate your help in troubleshooting the issue.
Quote - Hey guys,thank you all for your answers.I did what Glitterati3D said and it worked .However when i do this it fixes the part of the sleeve that i mentioned but it creates a similar problem to another part of the cloth such as the over back side of the sleeve.I f there is a way to fix that too please reply,if not thank you very much.I really appreciate your help in troubleshooting the issue.
It sounds like you "over" bent the elbow a bit, but now look at the shoulder on the parameters tab....under Rotation. You should find some bend, twist, side to side controls there. Very gingerly move the shoulder part into place, watching that you don't undo the bend.
Hello.
I would like your help to something that i can t find in poser.To be more specific ,i have noticed that in some figures when i bend their forearm then a part of the arm comes out of the sleeve.Why does this happen?When the whole arm (from the shoulder to the toes)is not bended everything is ok.Can you help me?
Thanks
