Fri, Jan 24, 1:35 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 1:08 pm)
Subject: .sit file for mac
povilasn ( ) posted Sat, 18 February 2012 at 4:30 PM · edited Tue, 21 January 2025 at 6:29 AM
Hello,
I bought Millennium baby and got .sit file how to use it for poser in Mac?
thanks
Miss Nancy ( ) posted Sat, 18 February 2012 at 5:12 PM · edited Sat, 18 February 2012 at 5:19 PM
expand with unarchiver.app (free) or stuffit expander (free from smith micro).  then use phil's runtime install tutorial.  if it's an old daz file, then it may try to install itself.  content providers should be aware that zip is the native compression format for OS X.
povilasn ( ) posted Sun, 19 February 2012 at 7:39 AM
I did wat was writen, but can not find file P9_start_unzip as is shown in this picture (I use Poser pro 2012)
What ai did wrong?
povilasn ( ) posted Sun, 19 February 2012 at 7:44 AM
This wat was shown on wb:
That waht I have: Why?
Miss Nancy ( ) posted Sun, 19 February 2012 at 3:22 PM · edited Sun, 19 February 2012 at 3:31 PM
[here's another page to try](http://www.philc.net/unzip.php), but it may require to knowing how to install content before one can use it.  the most frequent problem new users have with poser is how to install content. one can also try the poser/content/install from zip archive button (see attached image), after converting the file to zip.  my method:
  • decompress the file
  • see if it contains a runtime folder
  • make sure the runtime folder is enclosed in a folder with a distinctive name
  • drag the folder enclosing the runtime folder to poser/downloads folder.
povilasn ( ) posted Sun, 19 February 2012 at 3:47 PM
but .sit file has not runtime folder :(
All other I found how to instal, .sit - not
Eric Walters ( ) posted Sun, 19 February 2012 at 4:31 PM · edited Sun, 19 February 2012 at 4:36 PM
 A .sit file is a compressed file format-similar to a zip file.
If you open with stuffit expander- it should behave just like a zip file. Then you can manually place the files in your runtime.
If you get an old Daz installer as a result you may not be able to use it in OSX 10.7- this is a common problem- and Robynsviel suggested a program called "Wine Bottler" that allows you to run simple .exe based installers on the Mac. To do so you would have to download the PC installer for the Mil Baby and run it through Wine Bottler.
Miss Nancy ( ) posted Sun, 19 February 2012 at 4:33 PM
pov, post a screenshot of the expanded sit file, showing all filenames and extensions.
nruddock ( ) posted Sun, 19 February 2012 at 7:22 PM
As the MilBaby is from DAZ, the SIT file will contain an installer.
I wouldn't be surprised if the item is old enough for the installer to be one of the VISE ones that won't run under the more recent versions of MacOS.
You might get to the heart of the matter quicker by asking in the -> Macintosh forum.
povilasn ( ) posted Mon, 20 February 2012 at 7:46 AM
Thanks now I opend it with stuff expander, and got that when I tryed to instal it
nruddock ( ) posted Mon, 20 February 2012 at 2:13 PM
Quote - Thanks now I opend it with stuff expander, and got that when I tryed to instal it
The two things you can do are :- 1) Contact DAZ support and either ask for the installer to be updated, or a refund.
  1. Download the PC installer, install on a PC and transfer the files.
Miss Nancy ( ) posted Mon, 20 February 2012 at 2:41 PM
daz may allow an in-store credit to users who bought OS 9 self-extracting archives within the last 30 days, provided OP is unable to use a PPC with classic emulation, a dual-boot PPC or OS 9 computer to extract it.  if daz will supply a PC installer file, use crossover on an intel mac to extract the PC files.  if the file was not downloaded from daz, caution is advised.
I actually still have a dual-boot PPC with classic emulation, but haven't used it much.  nor can I convert OS 9 self-extracting archives for others without permission from daz.
