Sun, Feb 2, 5:10 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Feb 02 10:42 am)
Subject: Question about DSF Files
MarkR151 ( ) posted Sun, 19 February 2012 at 11:14 AM · edited Sun, 02 February 2025 at 1:53 PM
What are they & what's the difference between them and Preset files?
Or the difference between a DSF and a Scene file?
And what is a "Tri-Ax Weight Mapped Figure" and what does that do in creating a DSF Character file?
I know what Tri-X film was way back in the day, but never heard of Tri-Ax. What is their purpose?
mishamcm ( ) posted Sun, 19 February 2012 at 11:36 AM
DSF is a new file format which allows weight-mapping info, multiple UVsets, etc. in DAZ Studio 4.  It can be used to save scenes or presets which include weight-mapped items, but can't be read in Daz Studio 3 -- if you want a preset to work in DS3 also, you need to save as .dsa
Tri-Ax is the weight-mapping system DAZ 3D developed -- it's called Tri-Ax because the weight-map data uses 3 axes, as opposed to 1 axis in most weight-mapping systems.
MarkR151 ( ) posted Sun, 19 February 2012 at 12:03 PM · edited Sun, 19 February 2012 at 12:03 PM
What would be an example of a weight-mapped object?
SickenlySweete ( ) posted Sun, 19 February 2012 at 12:03 PM
one is the actual item ie..genesis or clothes, ect.. the other is just that a preset for applying a shader or saved dial pose or character
a dsf file is the actual item ie, clothes and can be redistributed..
the scene file is just for your own use so you can reload the work you all ready did.
that is the genesis figure and its items, no other figure has it..
as stated above that is what daz created for weight mapping ect..
www.bloodyrosesdesigns.com
http://www.aldaraproject.com/aldara/
http://www.dreamslayervisions.com
SickenlySweete ( ) posted Sun, 19 February 2012 at 12:04 PM
What would be an example of a weight-mapped object!
that would be genesis itself and all its items...ie clothes
MarkR151 ( ) posted Sun, 19 February 2012 at 12:04 PM
OK, thanks! Been wondering about that for a while.
mishamcm ( ) posted Sun, 19 February 2012 at 2:48 PM
Or any other figure that you weight-map, e.g. if you wanted to WM V4 or M4.
