Fri, Jan 24, 5:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Subject: Minor Assistance with Figure Creation Please
longhose ( ) posted Sun, 19 February 2012 at 12:00 PM · edited Fri, 24 January 2025 at 5:24 AM
Greetings,
I've finally gotten around to rigging Elsa's Ford. I probably could have picked something easier to learn this with but what the hey? I loaded the'donor' figure and made the necessary adjustments, edits, etc... and have finally arrived at a workable figure; however I still have 2 issues (with this project):
1st. How do I remove/hide the unwanted parameter dials. I assume that was a function of the joint editor but it's escaping my intellect I guess (Top Image)
2nd. Is it possible to remove the textures called for by the 'donor' figure. And if so how?
Any assistance at all would be appreciated.
Thanks,
Tom
(Using Poser 7)
meatSim ( ) posted Sun, 19 February 2012 at 12:07 PM
I believe you will need to edit the cr2 to get rid of both those things.  I think morph manager can get rid of the dials for you but not the material zones.
longhose ( ) posted Sun, 19 February 2012 at 12:18 PM
EXCELLENT!
Thanks MeatSim. That worked marvelously.
nruddock ( ) posted Sun, 19 February 2012 at 12:23 PM
Quote - 1st. How do I remove/hide the unwanted parameter dials. I assume that was a function of the joint editor but it's escaping my intellect I guess
Edit the CR2 to set the unwanted dials to hidden.
Quote - 2nd. Is it possible to remove the textures called for by the 'donor' figure. And if so how?
If you have materials showing up that are no longer required, you'll need to edit both the CR2 and the OBJ (or whatever you've used for the geometry) to remove all references to those materials you no longer require (but be sure that you have actually assigned some material to every polygon).
DarkEdge ( ) posted Sun, 19 February 2012 at 12:44 PM
Instead of deleting the dials, you might want them back at some future time; so you can also change the Hidden to a value of 1 in the CR2/PP2 file and it will just hide the dial from view. 😄
longhose ( ) posted Sun, 19 February 2012 at 12:49 PM
Sweet!
Thanks Guys!
Cr2Editor fixed my texture issues, I just had to dig a little deeper into the trees to find what I needed.
