Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 23 9:03 pm)
Quote - 1st. How do I remove/hide the unwanted parameter dials. I assume that was a function of the joint editor but it's escaping my intellect I guess
Edit the CR2 to set the unwanted dials to hidden.
Quote - 2nd. Is it possible to remove the textures called for by the 'donor' figure. And if so how?
If you have materials showing up that are no longer required, you'll need to edit both the CR2 and the OBJ (or whatever you've used for the geometry) to remove all references to those materials you no longer require (but be sure that you have actually assigned some material to every polygon).
Greetings,
I've finally gotten around to rigging Elsa's Ford. I probably could have picked something easier to learn this with but what the hey? I loaded the'donor' figure and made the necessary adjustments, edits, etc... and have finally arrived at a workable figure; however I still have 2 issues (with this project):
1st. How do I remove/hide the unwanted parameter dials. I assume that was a function of the joint editor but it's escaping my intellect I guess (Top Image)
Any assistance at all would be appreciated.
Thanks,
Tom
(Using Poser 7)
