DAZ|Studio F.A.Q (Last Updated: 2025 Feb 06 11:16 pm)
Generally the V4 or M4 model is loaded first, then the additionals like Aiko or Hiro or Freak injection files. Then I usually go for the base morphs, the ++ morphs, Enhanced, Elite, ect.
As long as you have the base V4 or M4 started the other sequences don't matter. I hadn't gone through the DS manual since I learned on my own, but I would suggest maybe finding the pdf file in your Studio folder and seeing if that may answer a few questions?
Quote - If you are using the PowerLoader script (if you et a dialogue when you bring the figure in) you don't need to add the morphs as a separate step.
But what do you recommend first Richard, loading V4 with Powerloader, or A4, which I think also has a Powerloader?
The character in question in this case is Taryn by SASE for A4. Although this could possibly also apply to any A4 based character.
Loading V4 or A4 will get you a figure, the difference is that if you choose the A4 version it will load with the A4 morph set to 1 (and if you use the Restore command it will restore to A4 = 1, instead of to a zeroed V4 as will happen with the Victoria 4 figure). Since you are going to be applying a character morph it doesn't matter which you load, as long as the needed morph sets were checked in PowerLoader.
Okay, thanks. If it truly doesn't matter which I load first, I may just do it in the order Taryn's creator mentioned in the ReadMe. I just wanted to be sure first cause I had heard/read conflicting info on which is the correct 1st step. Also, because some use Poser instead of DAZ, I wasn't sure if that was the reason for the conflicting info.
I felt like I needed to gather more info here in the DAZ forum first b4 getting started on that.
I'm a little confused about the workflow regarding what to load first for custom characters, including those that involve a non-Victoria figure like Aiko or Stephanie.
For instance, one of the ReadMes mentions "A4 - Load Aiko 4 base figure, apply Aiko 4 morphs, Apply V4 Morphs++, apply SV7 Taryn Morphs & Textures."
At the risk of asking another stupid question, is that the exact order you load these things for A4 characters?
I thought you always had to load Victoria first, then the V4 morphs, then the A4 or S4 morphs over that, and then the specific custom character over that.
Does the procedure vary from one character to the next?
