Wed, Dec 25, 2:01 PM CST
Subject: next silly question "clothing room"
shellysummers ( ) posted Fri, 24 February 2012 at 1:41 PM · edited Wed, 25 December 2024 at 2:00 PM
Ok so i am doing a picture with alyson. I make her basic sundress a black dress. In the options when i tried to clothify. I told it to colide with alyson body. For some reason it is not colliding with her legs right. There is tons of poke threw and and i get weird crumbling up around the knee joint. Reminds me when you use waredrobe wizard and the joints are not right. Anyone know what i am doing wrong? It's a dynamic outfit. Thank you for any help :)
MadameX ( ) posted Fri, 24 February 2012 at 2:48 PM
Not sure what the problem could be. A screenshot could help, maybe what version of Poser you are using, OS, etc.
Also, did you remember to turn IK off? That might not be what's causing it, but it should always be turned off on your figure whenever you use the cloth room.
If you already knew this, please disregard. :)
LaurieA ( ) posted Fri, 24 February 2012 at 3:43 PM
Could be you didn't let the sim run long enough. But we really can't help you with no image of what you're getting and no idea of your settings.
shellysummers ( ) posted Fri, 24 February 2012 at 6:54 PM
Ok so i re did the simulation a few times. Ran into it was leaving the invisible body parts at the root of the scene. Once I turned them back on. The simulation worked. Got to work on the pose a bit but thought i would show yall what i had in mind. Any suggestions you have on the picture would be greatly appreciated.
shellysummers ( ) posted Fri, 24 February 2012 at 6:57 PM
Ow can anyone please tell me why the pictures i try to upload are always so small? If i do't make them teni tiny they will not go on here. GAH!!!!
PrecisionXXX ( ) posted Fri, 24 February 2012 at 7:31 PM
What's the byte count of the image?  Just looking at it, that reddish background had an awful lot of detail, which equals heavy byte counts.
D.
The "I" in Doric is Silent.
shuy ( ) posted Fri, 24 February 2012 at 7:47 PM
Picture is too small. Best would be smooth shaded with wireframe.
I do not know Alyson, but she can have JMC and magnets in thigh/hip area. They are invisible, but can collide against clothing.
Delete simulation, create new simulation and manually check all body parts which can collide against dress. I think that with this pose you co not need check fingers, toes and head.
shellysummers ( ) posted Fri, 24 February 2012 at 8:00 PM
Quote - What's the byte count of the image?  Just looking at it, that reddish background had an awful lot of detail, which equals heavy byte counts.
D.
The byte count is 101 kb's it's a png. Is there a better format to use on this site?
LaurieA ( ) posted Fri, 24 February 2012 at 8:52 PM
shellysummers ( ) posted Fri, 24 February 2012 at 9:31 PM
> Quote - Ah, the forums don't really like .png. Try .jpg > > Laurie
seems to work better. Let me know what you think :) Ow is there a way to make the ground reflect her energy balls? I can see the feet, but the energy balls do not reflect.
shuy ( ) posted Sat, 25 February 2012 at 4:58 AM
  1. This picture does not shown all (I adviced wireframe preview picture - not render). I'm not sure, if I see correct, but I think that most of pants is selected as "constrained group". Check in clothing room. Constrained should be only "belt"
  2. Ground can reflect or gather light from objects. Go to material room, select ground and uncheck "shadow catch only". You can add reflection value node or create material which gather light.
Here you can find 9 links to threads refering lights and "gather"
mysticeagle ( ) posted Sat, 25 February 2012 at 8:05 AM
There are a few good reflective ground freebie props if you dont want to bother with mat tweaking, here's one
http://t3cat5.deviantart.com/art/Reflective-Ground-For-Poser-124178879
OS: Windows7 64-bit Processor Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical Processor(s)  6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad day........
Daz Studio Pro 4.5  64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
 link via my artist page
shellysummers ( ) posted Sat, 25 February 2012 at 9:33 AM
> Quote - There are a few good reflective ground freebie props if you dont want to bother with mat tweaking, here's one > > [ http://t3cat5.deviantart.com/art/Reflective-Ground-For-Poser-124178879](http://t3cat5.deviantart.com/art/Reflective-Ground-For-Poser-124178879) > >
Thanks, figured out the reflection because of that. Rerendered it and see the energy at the bottom.
