Sun, Dec 1, 6:08 PM CST
Subject: Transparancy
wolfmanjim ( ) posted Thu, 23 February 2012 at 8:13 AM · edited Fri, 29 November 2024 at 3:41 PM
I've been trying to make a transparancy pattern in P9 for the DAZ Fantasy wrap, but I keep getting the vague outlines of the wrap as a whole.  Any suggestions?
Glitterati3D ( ) posted Thu, 23 February 2012 at 8:19 AM · edited Thu, 23 February 2012 at 8:20 AM
In the Material Room, make sure your Transparency edge and falloff percentages are set properly.
It sounds like you have the edge setting wrong.
hborre ( ) posted Thu, 23 February 2012 at 8:24 AM
Transparency edge is most likely the culprit.
LaurieA ( ) posted Thu, 23 February 2012 at 8:27 AM
Also make sure you don't have any specular over the entire object. If you do have specular, plug your transparency map into the specular value. That way you won't have any spec outside the white areas.
Glitterati3D ( ) posted Thu, 23 February 2012 at 8:31 AM
One other thing.....make sure you render to see the effect of your transparency settings.  You will still see an outline in the preview window, but not in render if your settings are correct.
wolfmanjim ( ) posted Thu, 23 February 2012 at 8:37 AM
Transparancy edge was the issue!  Thanks, guys.
Anthanasius ( ) posted Sat, 25 February 2012 at 5:11 AM
Dont forget to put gamma to 1 if you use a map.
Génération mobiles Le Forum / Le Site
hborre ( ) posted Sat, 25 February 2012 at 6:40 AM
OP is using P9, Anthanasius.  No render gamma to worry about.
Anthanasius ( ) posted Sat, 25 February 2012 at 12:15 PM
:b_lipssealed:
