Fri, Jan 10, 1:30 AM CST
Subject: accessing the library when you're not online
rubicon2008 ( ) posted Fri, 02 March 2012 at 1:21 PM · edited Thu, 09 January 2025 at 7:37 PM
I'm trying a trial version of Poser 2012 pro on a studio computer that I don't have hooked to the internet (keeping it clean). However, when I go to Window and Library to open the library window, I get a message to download the new flash. Do I need to be on the internet to run the content library. If not, how do I access it. As I say, I get a large white window asking me html information. Your help would be appreciated!!!
Rubicon
FrankT ( ) posted Fri, 02 March 2012 at 1:29 PM
no, you don't need to be on the internet, but Poser needs to be able to access your local network card so you need to permit it through any firewalls you are using and I believe you will need either flash or air depending on which poser version you are using
My Freebies
Buy stuff on RedBubble
vilters ( ) posted Fri, 02 March 2012 at 1:30 PM
Poser talks internally to its library.
it does NOT need Internet.
But it does need Flash or Adobe AIR to function properly.
And you will have to give Poser permission in your firewall.
Search for your poser.ini
In there you will find a line
LIBRARY_IS_AIR 1
1 it is running on abobe air
0 it will run on Flash
You will need one of them at least: Adobe AIR or Flash.
But they are on the CD. (do not know in the trial version)
