Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:40 pm)
Thank you. :) I'm using this every day now. Very useful script.
"Dream like you'll live forever. Live like you'll die tomorrow."
Downloading now. Thanks Snarly!
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
thanks
Thank you so much for this wonderful tool!! :wub:
"Oh - the manual says that? I have never read the manual - this must be why."early morning question, can you use any skin from your mats library and apply easy skin to it?, i've read the pdf which has a great working description and how the various parameters affect renders, any chance of a dummies guide to ez skin?
OS: Windows7 64-bit Processor Intel(R) Core(TM)
i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical
Processor(s) 6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad
day........
Daz Studio Pro 4.5 64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie
maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
link via my artist page
Quote - early morning question, can you use any skin from your mats library and apply easy skin to it?, i've read the pdf which has a great working description and how the various parameters affect renders, any chance of a dummies guide to ez skin?
Yes, you can. EZSkin will analyse the skin shader that you have chosen and use the bits it needs from it.
As far the dummy's guide, I think the best thing to do is to post questions here in the forum. That way you're bound to get lots of help because there are lots of EZSkin users here, and I try to watch out for questions too.
On the other hand, if anyone did want to make a dummy's guide I'd be only too happy to see one made! Just don't have the time to make one myself.
Free stuff @ https://poser.cobrablade.net/
thanks snarly, gonna try it out tonight
day........
Carrara beta 8.5
maker
My freestuff
ok eejits question the next.......the ezskin xml file does that default to the basic v4 shader? and do i have to edit it everytime i want use a different mat to run ezskin pyc. and eejits q the 3rd, does the edit of the xml affect the figure mats py?
day........
Carrara beta 8.5
maker
My freestuff
Quote - ok eejits question the next.......the ezskin xml file does that default to the basic v4 shader? and do i have to edit it everytime i want use a different mat to run ezskin pyc. and eejits q the 3rd, does the edit of the xml affect the figure mats py?
You can generally ignore the ezskin.xml file altogether - it's there as an example for those brave souls who want to add support for new figures to EZSkin. EZSkin already supports most figures though.
No, the figure_mats.py script is there to help people who want to edit the XML file. You don't really need that one either. The only thing you need is the EZSkin script itself. It already knows how to add SSS to V4, in all her incarnations.
I have no idea what an eejit is but:
If you change the figures xml then yes it is going to affect how the script is run on the figure (and if not done right will make it not work). V4 should already be included with EZSkin. If you have a figure that's not supported (ie, doesn't have an xml file) then when you try to run the script a window will pop up and say that it's an unsupported figure.
You can of course create your own xml for the figure you want. The easiest way is just to copy one of those that are included, paste it and then change all the material zones to those of the figure you want and assign the skin type.
ok so let me see if i've got this right now, lets assume i DONT want to tinker with the xml for now, i select my eg v4wm figure and apply a mat to it for example the wm sss shader, i open the python, choose the additional options if i choose to and hit calculate and voila?
day........
Carrara beta 8.5
maker
My freestuff
Quote - ok so let me see if i've got this right now, lets assume i DONT want to tinker with the xml for now, i select my eg v4wm figure and apply a mat to it for example the wm sss shader, i open the python, choose the additional options if i choose to and hit calculate and voila?
Yes, it really is that simple!
thanks snarly, ive just unwittingly written my own idiots guide lol
day........
Carrara beta 8.5
maker
My freestuff
you wouldnt mind posting the link to the thread would you?
day........
Carrara beta 8.5
maker
My freestuff
cheers snarly one
day........
Carrara beta 8.5
maker
My freestuff
another question plz, any tips for render settings, i'm noticing using ezskin even on preview settings is increasing the time of rendering by average 800%....
day........
Carrara beta 8.5
maker
My freestuff
The primary reason for increased rendering times is the use of fresnel reflection on the ski. Disabling this will save a lot of time. If you don't want to disable it, consider reducing the reflection quality to save some time.
Eye reflections can also be time-consuming - using the original texture's eye reflection maps (if it has them) will save rendering time.
Of course all these time saving techniques will compromise the quality of the end result, but often the reduction in quality is minimal and the time savings considerable.
Attached Link: EZSkin 1.7.0
v1.7.0 has been uploadedIt now includes an option to override the bump value used by EZSkin with one of your own choosing. Useful for those occasional cases when EZSkin produces an exaggerated bump.
