Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 9:07 am)
No it wont remove the mat zones, just what's connected to them, ie the textures, it cuts down slightly on the file size and loading the cr will be faster as its not looking for map images in your textures folder
Tools:- Win10, Dell XPS8900, ZBrush, Marvelous Designer 11, Hex 2, PSP8. PSP 2019 Ultimate, DAZ Studio, Affinity Photo, Affinity Designer, Filterforge 11, flowscape, Classic UVMapper, and several headache tablets.
That all said here is a render of the direct conversions so far.
Quote - > Quote - so she's more or less stuck with dynamic clothes at the moment.
There's nothing wrong with that! :D
This is true... except for two things:
her dynamic clothes are made by me in Marvellous Designer.
my Marvellous Designer sewing skills are nearly as bad as my real life sewing skills (though I get less of the teeny puncture wounds in MD!)
:D
If you have Poser Pocket Knife, by PhilC (www.philc.net), there is a "Delete Morphs and Materials" feature in that Python script, so you'd be able to create a dev figure fairly quickly right from within Poser ...
The process, from start to finish, to create a DEV figure for Alyson is:
Load Alyson 2 into the scene.
Turn off IK (Figure > Use Inverse Kinematics) and zero the figure (Figure > Zero Figure)
Memorize the figure (Edit > Memorize > Figure)
Run Poser Pocket Knife (purchase from PhilC.net)
Thank you for the step by step. I thought I had just about everything from PhilC but looks like I missed this one. Will have to fix that.
Thanks to all you clothes makers for checking in. I honestly was getting worried that Anastasia might become another of my wisp of the wind figures.
Quote - > Quote -
One thing that should probably be clarified, though, is that this "dev figure" isn't used the same as in the old days. You can't just replace the OBJ file reference and have the weight maps work. You'll just use the CR2, which has the morphs and materials stripped out of it, to transfer the weight mapping to the clothing OBJ.
Import the clothing OBJ file that you want to conform.
Go to the Setup room
Drag and drop the icon for your dev figure onto the clothing OBJ file
Poser will ask if you want to regroup the OBJ file according to the skeleton. If the OBJ file has already been grouped manually, choose No.
Eventually a skeleton appears and you can then re-enter the Pose Room.
Select the BODY and change the name of the new clothing item in the Properties palette
Zero and memorize the figure
Save the clothing to the library
Now you should have a weight mapped piece of clohting. However, you'll have to test it to make sure it all bends as expected. There might be areas where the weight maps have to be tweaked in the Joint Editor. And that's the part we are all learning right now 8-)
and that's the bit I'm hating, I just don't know what I'm doing, lol.
My basic clothes that I've made have pokies when posing and I just tweek with scaling and z/x/y rots, need to sort out the last step but I seem to be going around in circles,
Having said that I've made a nice pair of dynamic baggy comfy trousers for her, she was getting a little fed up of dresses and rubber clubwear :)
Quote - Nice outfit!! I wore that style pants when I was a skinny youngun 8-) GREAT on the dance floor!
But remember ... I'm old enough to remember vinyl records. ;-)
I have a stack of vinyls in my wardrobe, some of my mother's too (Shirley Bassey 1950/60's ones) not worth anything as they are really scratched, I'm sure me and my sisters used to use them as frisbees when we were kids
I used to love those pants too, sadly I was never skinny :sad:
Quote - > Quote - Nice outfit!! I wore that style pants when I was a skinny youngun 8-) GREAT on the dance floor!
Well you're doing a great job!
I've just barely got one foot out of the grave right now ... on day 6 of a really bad cold and this is the first day that I can actually taste something. Maybe things are looking up! Still coughing, though not as much, and not nearly as achy ... but still have a slight fever.
Haven't quite been up to tackling my weight mapped boots but maybe tomorrow!!!
And 8 track tapes? I wore out the Eagles Greatest Hits 8 track...lolol.
Great looking pants Lully! :D
I never got into 8-tracks ... I didn't like that they would sometimes change tracks in the middle of a song. I held out for cassettes LOL
That looks really good!!
the setup room is freakin killing me with Anastasia... I'm currently going back to antonia for a bit to try and get my confidence back before I try to ressurect any of my anastasia attempts
Quote - > Quote - Now you should have a weight mapped piece of clohting. However, you'll have to test it to make sure it all bends as expected. There might be areas where the weight maps have to be tweaked in the Joint Editor. And that's the part we are all learning right now 8-)
[quote
that sounds like the flu, temperature and aches? keep yaself warm and take it easy,
I've just done a bit of a search around and compiled a list with links of anastasia stuff, or alyson2 stuff that can be used in combination, I've not gone into all the stuff that could be used with tweeking as I'm sure there are masses of things, I've done a page, if anyone wants me to add then put the link in this thread and I will pick it up and update the page.
http://www.lullys.com/anastuff.htm
i shrank her for the 20 frames to try and shrink wrap the dress, then went to 40 frames for the finished pose. tried again with drapes set to 6, for the strap around her neck.
is IDL supposed to make colors from the lampshade shine a bit of color on Ana?
wheee, 64 bits. the cloth simulation took minutes, not hours.
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Quote - Looks like your cloth is too stiff to me. Turn the cloth density up and turn the stretch damping way down to 0.0001. If you want a tighter fit, shrink the original dress, export and reimport and then shrink Ana then run the sim.
I think the lampshade will cast color if it's a light emitter.
yeah, doesn't look silky at all. i was trying for a 'spy who loved me' mood.
thanks for the stretch damping tip.
how low can those collision offset and depth be set before it goes wonky?
her hand is pretty close to her thigh. i had to make her thighs invisible cause she was poking through.
Quote - Do you have AO on too? AO will leave ugly spots on SSS skin if you're also using IDL. Check your light :)
I checked a few times and I'm pretty sure AO is off for lights and materials unless I missed something. I did a render without the dress on and the spots disappear, but obviously I can't post that so I guess I can just combine the two renders to make one final image.
Is there a freebie script that will turn on/off AO?
Anastasia usually comes across as a classy lady. eat your hearts out Kardassians.
Looks great so far.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
Skin is just the ana skin altered in paint shop pro, and the blinn reduced down in the mat room, althoug she looks rather red, lol
Morph is just a2 and gnd dials tweeked
Thanks Kalypso
I think she looks the spitting image of my old boss (YIKES!) which wasn't intentional but after I did that render I thought "oh my word, she looks like Pam!" So her morph is now called Pam lol
Hope you get your pc sorted out soon, I know what a pain it can be, a few years ago i went out the next day and bought a new pc as i couldnt wait and was having hissy fits because i wasnt online for a few hours and just bought anything cheap so i could get back online and into poser, bad choice of purchases back then and it lasted 18 mths and clapped out again. That's serves me right for buying rubbish. :(
Attached Link: ElfRaceGirl
Just another incremental update. The jacket was a bear to rig. Just a couple of parts left and I can start texturing. These are ParrotDolphin's awesome procedural textures from several of her sets. I'm also rolling around the idea of including some of Alyson's FBM's that work with Anastasia. Actually in this one the "BreastImplants" morph is applied.
Click for a biger version, and if you want the super-size version, you can go to the above link.
Quote - Just another incremental update. The jacket was a bear to rig. Just a couple of parts left and I can start texturing. These are ParrotDolphin's awesome procedural textures from several of her sets. I'm also rolling around the idea of including some of Alyson's FBM's that work with Anastasia. Actually in this one the "BreastImplants" morph is applied.
That is looking so fantastic!! :-)
Lovely! Am so looking forward to this!
Thanks for mentioning this outfit. I did not know that this outfit was for Anastasia also.
Quote - Got this recently and although the whole outfit isn't something I'd really use the individual bits are very useful and nice to have something that's a perfect fit on Ana instead of fiddling about with conversions.
http://www.renderosity.com/mod/bcs/little-red-outfit-boots/91211
Thanks Lilwolf, :)
"Just another incremental update. ......"
You are teasing us, :P
where about's is it gonna be available, RMP? need to start saving me pennies again.
Quote - Thanks for mentioning this outfit. I did not know that this outfit was for Anastasia also.
I love the boots in this outfit actually, they look great on Ana.
And it's on sale right at the moment too! :)
Quote - Yep. The plan is to sell it here in the RMP.
Great, as I check here more than anywhere else, :) Can't Wait
what is Blackhearted making next i wonder?
is there any news of Morphing Clothes utility and weightmaps?
it's an exciting time to work in Poser.
Quote - > Quote - is there any news of Morphing Clothes utility and weightmaps?
Yes, Dimension 3D has updated Morphing Clothes to work with weight maps, and it works perfectly!
If you've already purchased it, you can get the update in your downloads section.
Really? Oh JOY!!
It should. Nothing was done that would/could affect the material zones.
