Mon, Feb 3, 5:29 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Feb 02 8:19 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Making Pleats in Blender
EClark1894 ( ) posted Mon, 26 March 2012 at 12:36 PM · edited Sun, 02 February 2025 at 8:09 PM
I've been trying with very little success to model a skirt with pleats. I've seen it done, but for the life of me, I just can't make it work. Is there some trick to it that I'm missing?
LaurieA ( ) posted Mon, 26 March 2012 at 12:47 PM · edited Mon, 26 March 2012 at 12:48 PM
Start with a circle then shape it into a cross section of a pleated skirt (like it would look if you were underneath looking at it from the bottom). Extrude that. That's how I would do it ;)
EClark1894 ( ) posted Mon, 26 March 2012 at 1:13 PM
Thanks Laurie, I'll give that a try.
charlie43 ( ) posted Mon, 26 March 2012 at 1:15 PM
Laurie - this is something that has been bugging me, too. Could you post an image? Having a hard time wraspping my old brain around your explanation!
C~
LaurieA ( ) posted Mon, 26 March 2012 at 3:23 PM
Well, I was thinking along these lines, but more even and in a circle of course ;). Lots of vertex pulling, but I suppose you could do just one part and maybe use an array to copy it around the circle?
MWMPHX ( ) posted Mon, 26 March 2012 at 9:49 PM
The solution is... to do it in wings : )
Create a gear using the parameters box so you can set the number of teeth/outward faces. For instance I chose 12 to make three faces per quadrant. Select one outward face, hit the [i] key to select all similar. Scale uniform to suit. [Space] to deselect all and now select an inner face. Repeat above steps. You now have a solid 'primitive' you can export as obj and bring into blender to work the usual magic. Voila.
LaurieA ( ) posted Mon, 26 March 2012 at 10:30 PM
I tried MWMPHX's suggestion and managed to create some pleats in a very short time. Good suggestion MWMPHX ;).
LaurieA ( ) posted Mon, 26 March 2012 at 10:30 PM · edited Mon, 26 March 2012 at 10:32 PM
And from the bottom. This is Wings. I actually did the whole beginnings of the skirt in Wings.
MWMPHX ( ) posted Tue, 27 March 2012 at 1:51 AM
I'm glad that worked well for you. Not to knock blender at all - I've used it off and on from the very beginning and consider it a pro tool in its current form - but for just knocking out a quick mesh and unwrapping uvs I love Wings for its simple clean interface and unique toolset.
heddheld ( ) posted Wed, 28 March 2012 at 2:22 AM
have you tried the skirt as dynamic LaurieA ??   I tried it once in hex (same method lots more work lol) but it didnt work as dynamic ! all the pleats "fell out" an it looked aweful, maybe coulda got it better if I had known more about the cloth settings I think! have fun
NanetteTredoux ( ) posted Wed, 28 March 2012 at 9:01 AM
Yes, if you model pleats like that Poser's cloth room softens them a lot. Retaining the pleats with sharp definition would involve complicated fiddling with the properties and groups and I wouldn't know how to begin doing that.
Poser 11 Pro, Windows 10
unbroken-fighter ( ) posted Thu, 29 March 2012 at 1:06 AM
i just ran a basic skirt with pleats through the cloth sim in 7pro with no issues except that it was too simple to deform correctly
in blender i started with a 16 point circle and deleted all but 1/4 of it and then added the mirror modifier to make modeling easier
i then copied it and deleted all but 1 edge on the copy and then multi subdivided that and moved the verts to make the exterior of the pleats
again multi subdivide to make the interior of the pleats
then subdivide again to keep the edges from washing out when smoothed
extrude to desired length and add several loops for deforming
export and import and add the controls
