Carrara F.A.Q (Last Updated: 2024 Sep 07 1:44 am)
Nah, that's only going to change everything back the way it was, for example... I have a rig that was imported and I am attaching my model to it. I import the model, and I had to resize and rotate the model. What I want, is for the model to "pretend" I never resized or rotated it, and to accept its new size and angle as its "default"...
I tried importing, resizing, rotating and exporting AGAIN to import as a new object, but that didn't work =(
I need for the model to accept the new settings BEFORE I attach it to the rig you see.....
There are 3 kinds of people in the
world. Those that can count, and those that can't..
Ha! I knew that question was too easy!
I guess I'd have to see exactly what you're doing, but this may do the trick:
After you're done translating, scaling, and rotating your object, go Edit > Promote to Master; that should reset all of the translation values to zero without doing anything to your model.
Let me know if that helps!
JT
I must be doing something so wrong.....
Hey gang, hope all is good =)
Hopefully, this "should" be a quick question, lol...
Is it possible to have an object in Carrara, that when you imported it you needed to scale and rotate it, and now you want to tell Carrara to take these transforms and set them as if it were at 0 (in short, as if no transform ever happened?!?)?!?
Hope that makes sense...
Thanks.....
There are 3 kinds of people in the world. Those that can count, and those that can't..
