Sun, Jan 19, 2:04 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 15 2:29 am)
Carrara Free Stuff here.
Subject: Two questions
jackhalsey ( ) posted Mon, 02 April 2012 at 1:03 PM · edited Wed, 15 January 2025 at 10:24 PM
Hello
I have two questions one is so simple that I am amazed that I cannot figure it out.
1.  You load a poser scene in Carrara and then click on 3 point lighting...and it gives you a picture of two rocks....huh?  Does this mean the three point lighting has already been applied to the scene and where is it and how can you control it...
2.  The other is when I create a poser scene with V4 and put her in an outfit and import it into Carrara her clothes are strewn all around the scene...she cant keep her clothes on....how do I keep the clothes on her?
Thank you for your help
GKDantas ( ) posted Mon, 02 April 2012 at 1:17 PM
1 - I couldnt understand what is happen... could you post some screen shot?
2 - When cloths get unconrformed, simple select the cloth and in the side bar conform it to Vic as in Poser.
But why you add cçloths  and a simple Vic in Poser them save to open in Carrara since you can do all this right inside Carrara?
Follow me at euQfiz Digital
benney ( ) posted Mon, 02 April 2012 at 2:15 PM
The answer to your first question is this:-
When you select the "3 point lighting" preset your are essentially opening a scene file. With this in mind it is better to open the "3 point lighting" preset first then delete the two rocks (theses are just for display purposes). Once you have deleted the rocks then import the object or objects you want to use from poser via the "Content" tab.
I also agree with what GKDantas says. It is easier to load the naked model into Carrara then cloth directly within carrara via "Content" tab
Hope this helps..
jackhalsey ( ) posted Mon, 02 April 2012 at 3:16 PM
Thank you both will try these samples and report.
GKDantas ( ) posted Mon, 02 April 2012 at 4:13 PM
Try to import light setups from Poser. Carrara allow this a long time now, but you cant see them in Browser. It will open without cameras.
Use File / Import option in the menu.
