Sun, Feb 9, 2:50 AM CST
Subject: Option for making selected object not red?
chriscox ( ) posted Sun, 08 April 2012 at 10:56 AM · edited Sun, 09 February 2025 at 2:41 AM
Is there and option for having selected object not being turned red?
I've been making my way through the manual and looked under File>Options but maybe I'm missing something.
I find turning selected object red really annoying to work with and I am hoping that there is a way to stop it from doing that.
Thanks
Vue 10 complete, Windows 7 Home Premiun 64bit
Chris Cox
MaryHines ( ) posted Sun, 08 April 2012 at 12:29 PM
pretty sure thats exclusively an Infinite option
chriscox ( ) posted Sun, 08 April 2012 at 8:30 PM
Thanks for the replay.
It is really annoy to not be able to get rid of that red ghosting.  I see that it is listed as a "Feature".  Some feature, obscruing the detail of the object you working with by making it mostly red.
You are able to disable showing the wireframe of the selected object so I was hoping that the same could be done with the red ghosting.
I am considering purchaing Infinity.  However, unless I'm positive that the red ghosting can be disabled I might just pass.
Chris Cox
ShawnDriscoll ( ) posted Sun, 08 April 2012 at 10:28 PM · edited Sun, 08 April 2012 at 10:30 PM
You can change the red to a different color in Infinite.  You can't turn off the color though as far as I can tell.
bruno021 ( ) posted Mon, 09 April 2012 at 5:40 AM
It is possible to disable it in all Vue versions, go to File, Options, Display options, then untick "Show wireframe on selecetd object".
ShawnDriscoll ( ) posted Mon, 09 April 2012 at 9:27 AM · edited Mon, 09 April 2012 at 9:31 AM
I still see red.  Chris, let e-on know that Vue's highlighting can't be turned off even when it's deselected in the Display options.
bruno021 ( ) posted Mon, 09 April 2012 at 9:39 AM
Oh, yes, you're right, What I said disables wireframe, but the selected object is still red, solid red now. And indeed, changing this colour is Pro versions only. Sorry I was completely wrong on this one!
chriscox ( ) posted Mon, 09 April 2012 at 9:28 PM
Thanks for the replies.
It sounds even in Infinity its there, though you can chose a differernt color perhaps lessening the obscuring effect.
Chris Cox
ShawnDriscoll ( ) posted Mon, 09 April 2012 at 9:55 PM · edited Mon, 09 April 2012 at 9:56 PM
I changed it to a light blue-ish gray color.
