DAZ|Studio F.A.Q (Last Updated: 2024 Nov 14 2:47 am)
Where are you hitting the wall? It sounds as if you may be installing OK (just point the installer to the DAZ 3DStudioMy Library folder if you accepted the defaults) but are now looking in the Smart Content pane - if you instead use the Content Library (Window>Tabs>Content Library), under Poser Formats>My Library you will see a set up pretty much identical to what you saw in Poser (and native files will be under DAZ Studio Formats>My Library, though they aren't constrained by the Poser library structure within the My Library folder).
thanks for the answer and taking the time i would of got back to say thanks sooner its just im away at present . i noticed you said your content is not contrained by the program folder structure so where do you keep your i guress in a my library folder with identical folder structure but where and how do you then get the program to see it can you pick a kinda runtime folder like old poser dont understasnd thier new structure either :) thanks again pal
DAZ Studio doesn't have the Figures/Poser?props constraint. Native files can go anywhere except in the data folder (a bit like the RuntimeGeometries folder for Poser, and so off-limits), the Runtime folder (since that's Poser stuff, and textures for both Poser and DS usually), and the ReadMe's folder (which is hidden in DS, just to keep it out of the way). Still, most content does end up in one of several standard folders - People, with a subfolder for each character and then in that folders for clothing and materials, Props, with subfolders for various types of prop, and so on.
hi guys firstly i am gary pleased to meet you all now i here silly questions on momd forums that could not be serious but i swear this is im a new user to daz3d studio pro 4 i have downloaded a load of content off here to try in it and really get a good idea of whats what and i have no idea how to load this content i used to use poser and you clicked an installer and everything was sent to runtime and its relevant files and this content helper with daz4 pro is not helping any please somebody put me out of my simple misery i know it must be simple or is it only genesis stuff that works now ith studio pro4 ill sit like i am fishing and await an answer thankyou in advance where do i aim the content installer to and how do i find it in there either its not going in or i cant find it and i have spent hours at this now im very nearly at the stage of just bacl to modo and ZB. SAVE ME AND RECRUIT ANOTHER DAZ3D USER
