Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 6:38 pm)
Quote - Hello everybody,
I just installed the SR2 and adjusted the shortcuts (Poser.xrc) to my preferences.
Most of them work fine, but the ones with F-keys in them (e.g. F1, Ctrl+F5) don't.
They are displayed in P9, but when I hit the button - nothing happens.
Is anyone else experience this problem? And is this a bug or a feature?
Confused greetings,
Ome
You did submit a bug report to SM, right?
Thank you for the info, Medzinatar.
Although I got really angry when I read about the "unsupported use", and de-installed the SR2 immediately.
The function keys are the only ones that can be used solo, and excluding them seems to be kind of ... not very user-friendly.
So I really hope they will be back in Poser soon.
All the best and happy rendering,
Ome
Hi Steve,
It's really simple: Just open the Poser.xrc with an editor (e.g. Notepad++) and change the according entries. As an example, for the Main Camera I replaced "Ctrl+M" with "F1", the Aux-Cam is on F2, Posing, Face and Hand-Cams are on F5, F6, F7 and so on.
It's IMO a very convenient way to switch between views and makes poseing etc very easy.
Quote - So in otherwords it's a hack that's not supported. Thanks Ometeotl.
It may be an "unsupported" hack, but as is is a very useful hack that was de facto supported by the software before SR2. It would seem very stupid if they did not go all out to fix this for the next service release. After all, it's probably a very minor issue in terms of coding, and the time needed to fix it.
There has been no shortage of unsupported hacks over the years. Some of them have become major supported features in later versions. "Unsupported" in this context just means "it's not in the manual, or advertising, so we can't be bothered to fix it".
Lest this seems like all condemnation and no praise, let me say that in general SR2 fixes a lot of issues, some of them very important to me. For example PP2012 used add corrupt data to group names when spawning props from the Grouping Tool. That has now been fixed. In general, from what I have seen so far, SR2 seems to be an excellent piece of work, but that does not mean that it's beyond criticism in every aspect.
I have just installed SR 2.1 and the function keys now again work in shortcuts.
The SR overwrites previous version of Poser.xrc, so you will have to add any customization previously done.
My installation is English Language version, so I do not know if functionality was restored in other language versions.
Quote - I have just installed SR 2.1 and the function keys now again work in shortcuts.
Not if you tell it to use existing preference files when you install it it doesn't!
Hello everybody,
Confused greetings,
Ome
