Thu, Feb 13, 11:49 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: Eporting Image With no Background
DOSHL ( ) posted Wed, 18 April 2012 at 1:10 PM · edited Sat, 10 August 2024 at 8:26 AM
Hello,
I want to export a rendered figure from Poser Pro 1012 as a .png file and open it in another application - Flash - with no background.
When I try to export the image as a .png file, it opens in Flash with the upper top of the image with no background - just the figure.  But, the bottom half of the image has the figure and the background from Poser.
How can I export the image so that the entire background is transparent?
wimvdb ( ) posted Wed, 18 April 2012 at 1:14 PM
Turn off the ground (or set it invisible)
Turn off Ground Shadows as well if you don't need it
hborre ( ) posted Wed, 18 April 2012 at 1:20 PM
Online Now!
Ditto.
DOSHL ( ) posted Wed, 18 April 2012 at 1:21 PM
How do you turn off the ground or set it invisible and how do you turn off ground shadows?
wimvdb ( ) posted Wed, 18 April 2012 at 1:26 PM
From the menu: Display!Guides!Ground Plance - uncheck it
Or - Select then Ground in the Pose Window and Uncheck Visible in its properties
Disable Ground Shadows: From menu: Display!Ground Shadows - uncheck it
bagginsbill ( ) posted Wed, 18 April 2012 at 3:07 PM
Also Ctrl-G
