You could try Bagginsbill's VSS (Versatile Shader System), which will work in Poser 6...
http://sites.google.com/site/poserbagginsbill/vsshomepage
"Oh - the manual says that? I have never read the manual - this must be why."The map doesn't give the shine. Use a Blinn node or even the built-in specular component of the poser surface.
Specular maps are to break up the shine or modulate the shine as being more here, less there. But the actual highlights are produced by shader nodes. Blinn, Glossy, Anisotropic, Specular, ks_microfacet.
Connect a Blinn in Alternate_Specular at True White
Blinn Settings, at true White
Eccentricity =0.5
Specular Roll Offf = 0.5
Reflextivity = 1.0 => With the texture connected to the Reflectivity.
Click to enlarge
Start from here and adapt to your lights if needed.
Click to enlarge.
This setting gives a lot of flexibility, as (if required) you can also control the specular color with the Blin color if needed.
The connection to the texture in Reflectivity is (among others) to reduce the Blinn on the BROWS; Experiment and have fun.
Tony
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Quote - you mean this? this is done in pp2012 with reflection node and SSS. But since you dont have that, i would suggest making a specular map and plug it in to your fastscatter node and use a light wich makes the skin shine.
This is AMAZING.
Did you use a character that comes with SSS or did you do this yourself.
How to add the reflection map.
So many questions.
I do have PP2012.
Hello
How do I create a shiny effect on skin?
this is in Poser 6. I'm going to buy Poser 2012...soon.
bowiefan
