Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 21 10:29 pm)
It sounds like Poser Cross Talk. Not sure of the solution.
Maybe try changing the order you are doing things. Try loading the base figure, then the clothing, inject the clothing textures/morphs, and then inject the character morphs?
say." - Ghandi
i had a similar prob with V4 and couldnt find a solution that worked ...i had to settle for a work-around of setting min/max in the paramater dial for head size on the body level to zero(or whatever you want)... if its a personal use item i think this works fine, if its a sale item this is not an option .... hope you find this helpfull...
:O)
Y'all have a great day.
I knew a guy like that. He'd opened a bottle and a beautiful female genie appeared and granted him three wishes.
He said, "First, I'd like to be wealthy beyond dreams" So she made that come true. For his next wish, he said he'd like a private jet to take him to a secluded tropical island for a few days vacation. She told him the jet would be about 30 minutes.
So, looking at her and seeing how beautiful she was he said, "How about giving me a little head while we wait?"
Sam
:lol:
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
Regular V4 or a weightmapped one? I've been playing with a weightmapped M4 exported from Daz Studio into Poser 9 and just found that when applying a pose to him, it also "inflates" his entire body. As if I'd upped every Freak morph to maximum, but when I check none of the dial settings have changed. Undoing it merely returns him to the previous pose but will not restore his proper size. I thought perhaps the pose had a morph setting saved in it by mistake -- it happens. But that same pose works perfectly on a non-weightmapped M4 with the exact same character morphs applied. Nothing expands or shrinks then. Am using P9 SR2, if that makes any difference, and I've never seen Poser do that before either. Weird!
Quote - Regular V4 or a weightmapped one? I've been playing with a weightmapped M4 exported from Daz Studio into Poser 9 and just found that when applying a pose to him, it also "inflates" his entire body. As if I'd upped every Freak morph to maximum, but when I check none of the dial settings have changed. Undoing it merely returns him to the previous pose but will not restore his proper size. I thought perhaps the pose had a morph setting saved in it by mistake -- it happens. But that same pose works perfectly on a non-weightmapped M4 with the exact same character morphs applied. Nothing expands or shrinks then. Am using P9 SR2, if that makes any difference, and I've never seen Poser do that before either. Weird!
Birdie, I think that weight Mapped M4 is meant to be done completely inside poser, if it's the one from Poser Place.
At least that's my understanding.
Delaney
Quote - Have not got that one yet, this one is a regular M4 that I loaded into DS 4 Pro, injected his morph packs then exported him as a Triax weightmapped figure like you do with Genesis. But if there is another one around that I can get my grubby little paws on ... lemme at him!
I'm not sure they've released him yet, but they are working on him. I have the WM V4 which is a huge improvement on the regular v4. There's a script which you run on the DAZ 4.2 CR2 file and it rebones the figure making it weight mapped. You can even load all the morphs into the figure and then resave it yourself so you don't have to load morphs everytime you use it. It's pretty awesome. I got the toes fix here and installed it too on top of the others. I feel like I"m having my cake and eating it too. :)
They also have a script to reconfigure the clothing since it bends differently. I've noticed you even have to do it for the hair. The script for the clothing works on the Antonia WM stuff too and I presume new figures will be added to the menu for it as they go.
I kinda hoped when you said what you did that they had released him, already, cause I was going to go snatch him up.
I've heard that putting the daz Genesis figure into Poser has had rather lukewarm results. I haven't tried it yet, but if you are having results like this with the M4 one, then maybe I don't want to.
I am currently using Poser 2012 pro and when applying a texture pose to a clothing item (yes, the clothing item is the one active) the figure's head shrinks. Undo will undo the texture pose but not the head shrinking. It has done this on V4 and Alyson2. I've been using Poser since version 1 and have never seen the like. Any ideas?
Regards,
Verg
