Sun, Jan 26, 11:31 PM CST
Subject: Metaballs and Volume
Crakmine ( ) posted Fri, 31 August 2001 at 9:39 PM · edited Sun, 26 January 2025 at 5:42 PM
Ok, is there something I'm missing or do volumetric textures just not work on metaballs? I figured it would be a great idea to use metaballs to make volumetric clouds because it'd be real easy to get the slow flattened tops/bottoms of the coulds with the negatives, but when I put a volume texture on one no matter the size it comes up as nothing, any help out there?
Deathbringer ( ) posted Sat, 01 September 2001 at 12:17 AM
I believe that is a no go.. on volume.. tried it also with no results..
KAP ( ) posted Sat, 01 September 2001 at 4:13 AM
Nope, says so in the book...ditto on Booleen ops too.
joke ( ) posted Sat, 01 September 2001 at 11:11 AM
Metaballs don't seem to work with volu material - except if the metaball is palce right in the center of ground zero in Bryce. That don't help much -if anything. I found out about it accidentally.
