Thu, Feb 13, 8:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: Morphs++ not loading
Michaelab ( ) posted Wed, 02 May 2012 at 10:22 AM · edited Thu, 13 February 2025 at 8:47 AM
Hello all,
I have Poser 8. Have V4 and have tried to apply her Morphs++ for both head and body, but no ++ parameters are showing up in the Paramater list. Any ideas why?
vitachick ( ) posted Wed, 02 May 2012 at 10:31 AM
I'm also interested...Have Poser2012 same thing with Daz products...
Win10  Poser 2014/Poser 11 Daz3D
WandW ( ) posted Wed, 02 May 2012 at 10:57 AM · edited Wed, 02 May 2012 at 10:59 AM
Is Morphs ++ installed to the same runtime as V4?  Try reinitializing V4 by running the file (presuming you are on Windows)  DzCreateExPFiles-V4.bat found in Runtime/Libraries/!DAZ/
If you are on OS X, run DzCreateExPFiles-V4.command in the same location
hborre ( ) posted Wed, 02 May 2012 at 11:31 AM
Online Now!
It sounds like the initializing process was skipped as WandW mentioned.  Ditto on the response.
Michaelab ( ) posted Wed, 02 May 2012 at 12:57 PM
Thanks, **WandW**. I reinitialized that file and it did its thing, but still no ++ morphs showing up. Also, I have only one Runtime folder. Any other ideas>?
hborre ( ) posted Wed, 02 May 2012 at 2:49 PM
Online Now!
Where exactly are V4 and morph++ package located?  Those should be in the same runtime folder.  I notice you have a People folder in your P8; is that where V4 cr2 residing?
JAFO ( ) posted Wed, 02 May 2012 at 3:18 PM
this subject has come up before but i cant locate the link....IIRC when installing you have to install V4/M4 then the ++package then reinstall V4/M4 again then for some reason it works...good luck
:O)
Y'all have a great day.
hborre ( ) posted Wed, 02 May 2012 at 3:30 PM
Online Now!
My other thought on the matter, how old is the original V4 install?  There was an unannouced update over a year back on V4 to correct the creation of morph channels when initializing and updating.  I don't know how many morphs are being injected, but if, indeed, the V4 install is old, I would recommend resetting your download @ DAZ3D and obtain an updated version.
vitachick ( ) posted Wed, 02 May 2012 at 3:39 PM
Silly question..Reinstall V4 M4 to Poser?  Right now its installed to Daz
hborre ( ) posted Wed, 02 May 2012 at 3:43 PM
Online Now!
Mine is in Poser directly; Poser 7 to be specific.
vitachick ( ) posted Wed, 02 May 2012 at 5:39 PM
OK...Poser2012....reinstalled.....working...
Thank you!
Michaelab ( ) posted Wed, 02 May 2012 at 11:32 PM
Don't know what to do. I've done everything you all have asked above. I have downloaded again my original purchase from Daz of Vicky 4 base; then the ++ morphs, then Vicky 4 base again,  but no ++ morphs. I do have ++ morphs for Michael 4, but not Vicky 4.
ToxicWolf ( ) posted Thu, 03 May 2012 at 1:34 PM · edited Thu, 03 May 2012 at 1:36 PM
The only thing I can tell you is that I had the same problem in PP2012 and reloading V4 and the Morphs++ package fixed it. When you reinstalled V4 did you click the "Update Victoria 4" icon on your desktop? And I seem to remember something about initializing it, but can't remember what it was.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
hborre ( ) posted Thu, 03 May 2012 at 2:12 PM
Online Now!
The process for installing V4/M4 is during installation the prompts will ask to initialize.  After initializing and every time you install a morph pack, click on the update icon on the desktop.  Provided that there is the update icon available.  Otherwise, the DzCreateExPFiles-V4.bat, WandW suggested, is the other option.
ToxicWolf ( ) posted Thu, 03 May 2012 at 2:34 PM
Thanks hborre. I remembered what it was that was bugging me about it. I had to do it twice. The first time nothing changed. It was the second time that got everything working again. Kind of goes back to what JAFO was saying. I have no idea if I did anything different the second time, but at least it all works now. It also fixed my problem with the Aiko morphs.
Poser Pro 2012 SR3
24G RAM
MistyLaraCarrara ( ) posted Thu, 03 May 2012 at 2:39 PM · edited Thu, 03 May 2012 at 2:45 PM
the updater only updates the Daz default install of V4.
If you're using a V4 character you've saved, the new morph channels won't be added to it.
hborre ( ) posted Thu, 03 May 2012 at 3:06 PM
Online Now!
Excellent point to also note.
Michaelab ( ) posted Fri, 04 May 2012 at 10:25 PM
Quote - the updater only updates the Daz default install of V4.
MistyLaraPrincess - THAT WAS IT!!! I was trying to apply the ++ to a V4 I had saved.
When I loaded a fresh V4 and applied the ++ morphs WALAA!! Thank you, MistyLaraPrincess!! Your a life saver.
JAFO ( ) posted Sat, 05 May 2012 at 11:51 AM
bookmarking post for future reference... good catch Misty
