Mon, Jan 6, 11:53 PM CST
Subject: Mirroring Geometry
FreeBass ( ) posted Wed, 02 May 2012 at 11:27 AM · edited Sun, 05 January 2025 at 7:38 AM
I hope it's not too much to ask for, but I'm looking for a script or util that will easily mirror a Poser figure/ prop's geometry. (Rendering & mirroring the image is not an option). Take a pair of shoes as an example; assume I found a really cool shoe on a freebie site ('cuz I wouldn't wanna pay fer a single shoe). I would like to be able to uv/ group/ rig that single shoe then flip it to complete the pair as separate figures and save myself from having to do it all twice. Any ideas or suggestions?
I would also like to know about mirroring morphs; I've seen scripts to mirror morphs w/in a single symmetrical figure (right to left), but I wonder if they would work (or if there are others I haven't seen) on a separate full object w/ identical but reversed geometry.
TIA
WARNING!
This user has been known to swear. A LOT!
basicwiz ( ) posted Wed, 02 May 2012 at 12:17 PM
I believe these products might be of help:
http://www.renderosity.com/mod/bcs/content-mirror-for-poser/80640
http://www.renderosity.com/mod/bcs/poser-tool-box/87010
I've used both author's stuff personally, and both are top-notch, both in quality and support. Check and see if they will do all you need.
Anyone else with a tool I've missed?
PhilC ( ) posted Wed, 02 May 2012 at 12:52 PM
Yes, the Poser Tool Box has that option. You can mirror about X, Y or Z axis.
lesbentley ( ) posted Wed, 02 May 2012 at 3:35 PM · edited Wed, 02 May 2012 at 3:42 PM
For those on a budget. This method involves a bit of work, but it's free.
This seems to work for me as a free way of mirroring an obj. It is not quite exact to the n'th decimal point, but close enough for me. What follows is instructions for mirroring across the x axis, but it should  be obvious how to adapt it to mirror across any axis.
Load a poser 'square' primitive. Import the obj file you want to mirror, with all import options deselected. Let's say your obj is named "MyThingie". Once imported the obj has become a prop (=has transform channels and material settings). Parent MyThingie to the square. Select the square and in its Properties click on its 'xScale' numeric field. Type in the value '0.0001', and press Enter.
From the file menu export your prop, adding "-Morph" to the name, eg "MyThingie-Morph.obj", with only the 'Include existing groups...' export option selecte. Delete the square, then Restore MyThingie (Ctrl+E). With MyThingie still selected, from the Object menu, use 'Load Morph Target' to load 'MyThingie-Morph.obj'. Express the morph at a value of 2.0.
Export MyThingie as "MyThingie-Flipped.obj", with only the 'Include existing groups...' option selected. Delete MyThingie from the document. Import MyThingie-Flipped.obj, using only 'Flip Normals' in the import options. This is your final mirrored object. Save it with whatever name you want to use.
LaurieA ( ) posted Wed, 02 May 2012 at 3:41 PM · edited Wed, 02 May 2012 at 3:43 PM
You can also do it in Wings, which is also free :). Object mode, duplicate the object, with the object selected, Flip X or whichever direction you want to flip it. Then do an absolute command Move and then + or - the coordinates.
jancory ( ) posted Wed, 02 May 2012 at 6:30 PM
Attached Link: http://skinprops.com/download.php?list.8
or spanki's S.T.O.M.P., also free
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
mrsparky ( ) posted Wed, 02 May 2012 at 9:17 PM
jancory - thanks for that one .That'll save hours of work! C5 doesn't alway create a good mesh right when you flip.
FreeBass ( ) posted Sat, 05 May 2012 at 5:16 AM
Tanx fer the input all  :)
WARNING!
