Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 22 10:18 pm)
You are also not using Gamma correction...
"Oh - the manual says that? I have never read the manual - this must be why."Quote - BTW: if you are not using SSS in your skin texture, turn it off in your render settings.
Why? If you have no scattering materials that pass is not performed.
If, on the other hand, you habitually keep it turned off, and then you load a scatter material, and you forget to turn it back on, you will be sorry.
Turning it off when you need it on - bad news.
Turning it on when you do not need it on - no impact.
Your lights are behind the head - the eyes are not going to be lit well. What's the question exactly? Are you confused because the skin is lit, and the eyes are not? We can guess and guess till the cows come home, but I expect NOTHING on the front to be lit.
As hborre said, looks like the skin is glowing - self lit.
Do a render with all lights turned off. If you can see anything at all other than blackness, you have crappy shaders there.
The inside of the mouth and the teeth are lit, and that is impossible from your lights positions.
So as BB said, you have a skin shader problem.
probably some ambient crept in.
Go through your shader setup and remove all ambient there.
With the lights you are showing the mouth inside should be BLACK.
i think your eyes are the only ones having the right shader setup,
it is the rest of the face that has a problem, including the teeth and inner mouth..
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
Hello all!
I have a problem...when I render a face in light I get the eyes, but when the eyes are in shadows I get a deep black void...I know the eyes are there but this is just not natural as you may see in the images...what could be causing this?
