My system is way less powerful than yours, and I get smooth results with
Poser 8, Screen window and actual transparancy.
Unfortunatly I do not see anything else different from mine (i5-750 ATI Radon)
Try that, and if it does not work maybe someone else has suggestions.
Bill
IIRC... there is a line in the Poser.ini file...
Open your Poser.ini file in a text editor (eg. Notepad)
Change:
PREVIEW_OGL_OBJECT_BBOXPICKING 0
to
PREVIEW_OGL_OBJECT_BBOXPICKING 1
The Poser.ini file is located here (or some reasonable facsimile):
C: > Documents & Settings > Poser > Application Data > Poser 8 > Poser.ini
Also... Do you have all the service releases applied?
Those preview settings look quite moderate to me; I wouldn't think they would be a problem, with your video card. You might try setting the offscreen handling to scene window.
For what it's worth, I frequently switch preview settings, using a quick/rough setting if the OpenGL/hardware shaded setting is reacting slowly, then switching back to get the best preview for a final check before rendering.
Since your current project is reacting slowly, this won't be helpful, but for other scenes, if you're using tiled materials, or using procedurals, try engaging hardware shading; this mode will display materials tiled (it helps you set scale and line up U,V offset) and show procedurals with scale, phase, and frequency. It is the most demanding preview mode, so it will be the slowest. But it's great for working up materials.
OSes: Win7Prox64, Win7Ultx64
comparing with my settings:
I have Scene Window instead of PBuffer
I have Enable hardware shading checked
my Preview texture resolution is 512 (and should be1024, frankly)
and in General Preferences, Render tab I've Texture Caching set to 500Mb, should be more
Running PP2012 BTW, see my signature.
Good luck
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
Hi
I think you have something more basic then you Poser setup going on here.
My system is 2 years old and I get almost instantaneous refresh even with my setting at almost max, I even have texture res set to 4096.
The only thing I turn off is antialiasing.
I use Scene Window same as aRIBee.
Make sure your video drivers, memory config and things like that are all up to date.
Run CCleaner and defrag, (it can't hurt), I use Defraggler because you can just defrag files without doing the whole drive. It makes a noticable difference and I do it almost every day.
I don't have any real idea what's going on but I think something in you computer isn't quite right some place, I guess I can't be less specific then that.
Are you a gamer? Do you get high frame rates in games?
Mike
If you shoot a mime, do you need a silencer?
Hello. I hope someone can help my situation. Let me begin be describing my system. I have an I7 950 running on a X58 Sabertooth mobo, 16gb ram, a new MSI GTX560Ti 2gb video card, 300gb hybrid drive, windows 7 64 bit and Poser8 with updates. I just replaced my old GT220 video card with the new MSI GTX560Ti. My problem is that my preview screen, for lack of a better word, sucks when it comes to frame rates. If I have more than one character on the screen, I need to switch to fast mode for character manipulation or the motion is so choppy it makes accurate posing impossible. I've played with the render preview settings and yes, the open gl hardware is enabled. I've also tried numerous settings and combinations to clear up the problem. I can understand this condition with the old card, but this new card should easily handle the load. A very good friend of mine is running a similar system with less ram but the identical card and poser pro 2012. His preview is smooth as ever with a great frame rate...if you will. I have trouble believing that poser 8 and pro 2012 would have such a radical difference in the preview screen seeing as how both programs use the video GPU for this function. Any suggestions are welcomed and appreciated. Thanks.
