Tue, Nov 26, 6:06 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 26 5:46 am)
Subject: Ghost Bones issue
Channing ( ) posted Sun, 06 May 2012 at 7:30 PM · edited Fri, 22 November 2024 at 12:57 PM
Hi,
I'm hoping to get some advice. I have a figure with ghost bones in it that is crumpling the mesh influenced by the bones once I turn on "Use Limits" in Poser. I've tried adjusting the forceLimits parameter in the rotation channels, but that does nothing to help.
I'd be grateful for any tips, or perhaps a pointer a relatively recent Renderosity store product that has ghost bones in it so I could look over its cr2 for pointers to correct the code in my own figure.
Thanks in advance.
icprncss2 ( ) posted Sun, 06 May 2012 at 9:23 PM
What figure and what version of Poser are you using?
Without more information and perhaps a screenshot, it's very hard to determine what the problem and the solution is.
Channing ( ) posted Sun, 06 May 2012 at 9:34 PM
  1. Figure is my own product that is a mod of the M4 Gens so a screen shot is probably not possible here unless I do a closeup.
  2. I've checked it in Poser 8 and Poser Pro 2012. Same problem occurs.
lesbentley ( ) posted Sun, 06 May 2012 at 10:12 PM
Quote - I have a figure with ghost bones in it that is crumpling the mesh influenced by the bones once I turn on "Use Limits" in Poser.
Try setting the the min and max limits to a large enough value so that it does not matter whether limits are on or off, eg:
                forceLimits 0
                min -100000
                max 100000
Channing ( ) posted Sun, 06 May 2012 at 10:26 PM
Alright. I went to the xrot,yrot and zrot channels and made the min and max limits and forceLimits values as you wrote them above. It still happened.
Do you think I didn't go far enough? Should I change all channel values (scaling, trans, etc.) to what you suggest?
Channing ( ) posted Sun, 06 May 2012 at 10:56 PM
And the solution, for anyone in the future searching for the answer to this question:
 The problem was in the scale, rotation and translate channels. All of them needed to be reset as follows:
Scale channels:
forceLimits 0
min 0.1
max 100000
Rotation  and Translation channels:
forceLimits 0
min -100000
max 100000
The crumpling mesh has now gone away.
