Fri, Jan 10, 7:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Not able to freely move props in figure
attilako ( ) posted Sun, 13 May 2012 at 1:59 PM · edited Wed, 08 January 2025 at 2:10 PM
I had several props which I grouped in one figure (to save place on the animation palette)
The props became bodyparts, but I want to move them freely in poser scene, independent of its body. ...and that's what is not possible. Even if I turn the "bend" parameter off.
Do you know a way to give them free transition?
Thanks
SamTherapy ( ) posted Sun, 13 May 2012 at 2:04 PM
Depends how you did it.  If you created a figure properly, you should have access to the translate and rotate dials.
Quite often the translate dials are hidden by default.  Markschum made an unhide script to show them, or you can edit the cr2 to show them.
Acadia ( ) posted Sun, 13 May 2012 at 5:04 PM
Maybe try parenting them to the Universe instead of to the figure itself?
shuy ( ) posted Sun, 13 May 2012 at 6:28 PM
Unhide dials and set high limits.
http://d3d.sesseler.de/index.php?software=poserpython&product=unhide_dials
attilako ( ) posted Mon, 14 May 2012 at 2:38 AM
Thanks for the ideas, I can now move them with the mouse,
but not with the 3D mouse (3D Connection)    ... and unfortunately I use the 3D mouse 95% of the time.
SamTherapy ( ) posted Mon, 14 May 2012 at 9:57 AM
I'd never use anything but the parameter dials (or rather, the numeric inputs) to move body parts.
attilako ( ) posted Sun, 22 July 2012 at 4:53 PM
 I can only  move them with the parameter dilals.  If I do it with the mouse the objects(bodyparts) are rotating around the center, and I can't move the freely
