Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 15 2:13 am)
MT5's are not textures. They are shaders which can reference textures, but they are not the actual textures. If it says "can't load texture.bad file." I am surprised, since professional programmers are not allowed to spell that way. Could you tell us exactly what it says? Assuming it's close to that, the simplest explanation is - you have a bad texture file, i.e. a corrupt JPEG or something. We'd have to know what is in the shader - what file is it asking for - to be sure.
You are trying to select a material as if it was a picture. You're going about it all wrong.
You double click the mt5 file in the library window and it will fill in the whole material - it's not a picture.
you can open the mt5 in any text editor to see what it is referring to.
If you can not find a bad image file perhaps you can post a screencap of the mt5 file so we can see how the file is being referenced.
Ideally all file paths will be relative paths and use : as the seperator like
":runtime:libraries:materials:mymats:thismatfile.mt5"
For an MT5 file, to apply in the pose window in P8, you have to drag and drop, you can not double click.
from the material room, you select object, open library and double click icon.
An mt5 file can not be applied with the browse button
Bill
Open the library while in the material room. apply from there.
I am not sure on MAC, but ctru-shift B on windows will open it.
you CAN NOT navigate to an mt5 file and apply the way you are trying.
It must be appled from the library.
Bill
I recently purchased content that has materials in mt5 files. I get a "bad file" message when I try to use them. This is the second time( different product) this has happened, I can't use the content. I have Poser8 on a Mac. The files have been installed according to the "read me" instructions. I have contacted the content creator, it does not appear she has the answer as to why my computer can't read the files. Smith Micro says there shouldn't be a problem reading mt5s on my computer, and I should go back to the creator of the content. Has anybody had this problem?
