Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Yes you can. Name the script myScript###Ctrl+Alt+D.py and save it in your ScriptsMenu folder.
Next with Poser closed open RuntimeuiPoser.xrc in a text editor.
Search for "Ctrl+Alt+D"
If found disable the line using the comment notation.
Save.
Restart Poser.
Use Ctrl + Alt + D to make it run.
hmm, thanks PhilC but I can't seem to get this to work, tried commenting out the line, and the object in poser.xrc, renamed the script and even linked it to the menu script..
but Ctrl+Alt+D does nothing when the python window is selected and opens different views when the main object window is selected.. any ideas what I'm doing wrong? I'm on pro 2010 if that makes any difference.
Thanks.
Other than not following the instructions exactly, no I do not. I double checked it and it is working for me.
What do you mean by "even linked it to the menu script" ?
It should not matter what you have selected at the time.
You should only comment out the "accel" line not the full object.
What happens when you run the script from the Poser Scripts menu?
ok, I have a folder called 'poserScripts' in python where the 'mainButtons.py' is I put 'myScript###Ctrl+Alt+D.py' in that folder and then add:
poser.DefineScriptButton(9, ":Runtime:Python:poserScripts:myScript###Ctrl+Alt+D.py", "myScript")
to mainbuttons, I then just delete ''Ctrl+Alt+D" from 'Poser.xrc' in the UI folder.
when I click 'myscript' in the poser menu it runs fine, but Ctrl+Alt+D will cycle through views if the preview window is highlighted, or do nothing if its not.
sorry if I'm being stupid here, probably missing something obvious.
thanks for this tip!
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
As the title says I'm wondering if it is possible to assign a key press to activate a script... would not have thought so (and can't find anything in the manual) but since there are only a set amount of buttons there, thought it was worth asking...
thanks.
