I get that all the time, especially if I've used DAZ installers. Unless I think something about the install was odd, I just x it off. It doesn't seem to cause any problems.
Life may not be the party we hoped for but while we're here we should dance.
I think that popup is just Win 7 being too sensitive about the anticipated results from the user's input if that input(installation) deviates in any way from Window's built-in programming parameters!
What I do when I get that message popup is go ahead and run the program, and if it runs as I expect, I just hit the "installed correctly" button and am not bothered about that installation again.
If it didn't install and runs as I expect, then I hit the "re-install using recommended" button and see if that fixes it. If It didn't install correctly with Windows doing the installation, I manually install it again and usually it works on the reinstallation - I have never had to manually reinstall more than 1 time on my 32 bit Win 7 machine.
Hope that gives you some sense about how to deal with that bugaboo.
windows 7.. bryce 7 pro..
i gave in my laptop for a health check up as the warranty is getting over in a month or so. i now have to reinstall everything.as they happily wiped it out..gave me a clean slate..with my permission..of course.
i wanted to reinstall bryce anyway..completely..as the past few times..when i've had to install bryce..i kept getting a weird message for everything i installed... a pop up window came up saying that the program it seems wasn't installed properly...and it gave me two options.. re-install it again..or ignore msg.
i'd click on re- install it again..and it would be ok after that. it did that for content, bryce, daz..everything.
before i start intalling bryce now... why does that happen and how do i avoid that?
i just installed a fractal program freebie..and got the same issue. is it with anything to dow ith graphics as other programs..not that me putting much on..doesn't have that same probs.
help!!
