Wed, Jan 8, 6:11 PM CST
Subject: I need a HUGE preview window. Will dual monitors work??
operaguy ( ) posted Wed, 23 May 2012 at 7:21 PM · edited Wed, 08 January 2025 at 5:48 PM
I have need to get the document window (preview) to open very large. In fact, i need 2048x1536 minimum, sometimes in landscape, sometimes in portrait.
I am aware that working in, say, an 800x600 document (same ratio) does not stop you from rendering at 2048x1536, that works fine. However, I have a certain special need: to render animation in preview at full 2048x1536 and/or 1536x2048.
On my 1920x1080 monitors I cannot get the preview window open to more than 992 high, and on 1920x1200 Dell a little more although i have not tried that yet.
So, here are  my questions if any dual monitor gurus see this post:
  1. is there a way to fool Poser into opening a huge document/preview window on a normal monitor?
  2. implementing dual monitors, can you get them in "over/under" relationship?
  3. will the document window open up across the dual monitors?
I have two dells that go up to 1920x1200, so in over/under mode that would be 1920x2400 and that would cover me for 1536x2048.
There seem to be various monitors on the market that will go to 1536x2048, but a) i already have multiple large monitors; b) it would have to pivot; c) i bet you still can't get the Poser document window open sufficiently, and d) i do not mind working in the preview window across monitors.
I am running PoserPro2012 on Windows 7 64 bit.
Any wisdom much appreciated,
::::: Opera :::::
bagginsbill ( ) posted Wed, 23 May 2012 at 7:28 PM
I am on an airplane and cannot check, but doesn't the render dimension dialog apply here?
LaurieA ( ) posted Wed, 23 May 2012 at 7:28 PM · edited Wed, 23 May 2012 at 7:32 PM
I run Poser Pro 2012 with two monitors. The only panels that remain on the monitor with the preview window are the one's I CAN'T move ;). Just be advised you'll have to the panels on each room tab individiually, and the floating dock will stay the same size and in the same place between tabs. Set up the library panel first. Then place the other panels around it.
edit: my monitors can't do the resolution you're referring to, so I can't tell you anything about that ;). You can expand the preview window across both monitors, but then you have the problem of covering up your other panels ;).
operaguy ( ) posted Wed, 23 May 2012 at 7:45 PM
Laurie that is good news that the preview window WILL function across monitors.
I operate with few panels open...just the light and camera widget and the parameter dials. I click open the graph a lot from the dials. Animation slider docked at the bottom.
now...i have to find out if dual monitors can be taught to function over/under as opposed to right/left.
BB in this special case I am NOT rendering firefly. Only rendering the preview. Also, please turn off all electronic devices that could cause your plane to crash! We need you.
::::: Opera :::::
WandW ( ) posted Wed, 23 May 2012 at 7:49 PM
Quote - I am on an airplane and cannot check, but doesn't the render dimension dialog apply here?
I've used Poser on an airplane wthout issue.  :tongue2:
However, technically it is a violation of DAZ' license to carry their content around on a laptop...
uli_k ( ) posted Wed, 23 May 2012 at 8:13 PM
You can select the Preview renderer for final output (Document window > Render tab or Render > Render Settings). Then the Render Dimensions dialog applies, as bagginsbill suggests. As an added benefit, you get an anti-aliased image if desired.
stewer ( ) posted Wed, 23 May 2012 at 8:16 PM
Quote - BB in this special case I am NOT rendering firefly. Only rendering the preview.
I think he is very aware of that. The preview render engine does not depend on the size of the preview window. You can render a 4096x2048 preview animation on a screen that is not even half the size. I just did.
operaguy ( ) posted Wed, 23 May 2012 at 8:17 PM
really. i must have missed that! are you renderinng the movie out to image sequence?
off to explore how.
operaguy ( ) posted Wed, 23 May 2012 at 8:34 PM
OH! You click on the little button at the lower left in the "Make Movie" window. It lets you change the render production area.
It worked!
Wow, solution!
operaguy ( ) posted Wed, 23 May 2012 at 8:39 PM
I guess I should tell what the hell i'm doing!
Not going for realism...just the movement of characters, clothing and hair. Turning on various preview OpenGL features. Also using strand hair with "show populated" selected. Very fast render time with preview engine out to image sequence. Significant post-processing.
Going for iPad3 resolution.
::::: Opera :::::
EnglishBob ( ) posted Thu, 24 May 2012 at 3:58 AM
Quote - I've used Poser on an airplane wthout issue.  :tongue2:
So have I, but I've never posted on a forum while in flight. :tongue2:
However I hear that some airlines are making Wi-Fi connections available for passengers.
aRtBee ( ) posted Thu, 24 May 2012 at 12:13 PM · edited Thu, 24 May 2012 at 12:22 PM
I've got 2x 1024x1280, and I can tilt either of them or both (great for portraits).
Sometimes I just tear off the document pane (that very tiny square at the utmost upper right, which says Dock / Float / ...
This image shows Poser at the left monitor and the floating document pane at the right monitor.
aRtBee ( ) posted Thu, 24 May 2012 at 12:21 PM
and sometimes I un-maximizes the Program and drag it over the full width (using the maximize button tells Poser to use the formal desktop = monitor, unless you're using special software like UltraMon (Realtimesoft.com) which gives you a real multi monitor desktop.
