Thanks djthomas. Jaager - I actually use the upper eyebrows most of the time... I just didn't with this particular texture... I have two versions... one has the eybrows painted out completely, which I use the upper eyebrows with... I think the upper eyebrows are great actually, you can make some very interestingly shaped eyebrows with varying the trans. map.
Cin- actually, I thought you Were using the material, it was the other advice, I was commenting on. On your render with the pink bkgrd, the left eyebrow has an outline. Is this because of a diffenece in skin texures, or is there something other than pure black on the highlight of a transparent layer? The right does not seem to have it.
