Tue, Feb 18, 12:28 AM CST
Subject: A question anyone can answer...
MatCreator ( ) posted Wed, 30 May 2012 at 9:01 AM · edited Sat, 08 February 2025 at 9:59 PM
I totally forgot =/
What are the command keys to export an object from the Bryce Preview Window?!?
We had to have the "edit" prompt open for it to work correct?!?
Brain has been butter for a while =/
There are 3 kinds of people in the world. Those that can count, and those that can't..
kiwi_gg ( ) posted Wed, 30 May 2012 at 12:53 PM
"control d" if My old memory is correct . Later versions of bryce its in the "file" dropdown menu.
CheeRs
GG
WHO said Kiwi's can't Fly ?????
MatCreator ( ) posted Wed, 30 May 2012 at 4:46 PM
I tried that, it's not working tho =/
I do see the export option, didnt know the other method was removed.
Thanks a ton =D
skiwillgee ( ) posted Wed, 30 May 2012 at 8:36 PM
Ctrl+d  will duplicate a selected object.
MatCreator ( ) posted Wed, 30 May 2012 at 9:01 PM
Youre correct skiwillgee, but when the edit prompt is open, it "used" to begin an export function.
Seems it's been replaced/removed and is in the edit menu now.
kiwi_gg ( ) posted Thu, 31 May 2012 at 12:47 AM
AFAIK both are correct. I think it was 6.3 where the "control d" from the edit option  where you did smooth/unsmooth on exit you were given a list of file formats you could export to, this function was moved to the file>export position.
Cheers
GG
kiwi_gg ( ) posted Thu, 31 May 2012 at 2:40 PM
Ok, I had some time to look at this. "control d" will indeed produce a duplicate object from your normal screen of any object you may have highlighted, however from the "Edit Mesh" window control d has an entirely different function.
With your object highlighted you must have the "E" visible in the dropdown menu, click on this to bring up the edit mesh window where you will have the option to smooth/ unsmooth your object. Without doing any smoothing operation if you hold down "control + d" and "exit the edit mesh window" at the same time you are then presesented with a save window from where the object can be saved in a number of other file formats.
"control+d" still works in my Bryce 6.3 but no longer available in 7pro where you now do File>export. Screen-shot is from B5.5.
Cheers
GG
MatCreator ( ) posted Fri, 01 June 2012 at 4:40 AM
So long as the function exists =)
Shows how out the loop I am...
bobbystahr ( ) posted Fri, 01 June 2012 at 9:12 AM
what kiwi_gg said....
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
