Tue, Jan 14, 1:16 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 13 3:34 pm)
Subject: Basic ground interaction question
fleshoff ( ) posted Fri, 01 June 2012 at 10:09 PM · edited Tue, 07 January 2025 at 9:31 AM
I'm animating an object but I want to prevent it from going beneath the ground plane. I know it's probably very simple but my internet searches are coming up empty. I know about drop to ground but this is an animation and while I start on the ground as it moves it goes under it. Thanks.
www.insectula.com
Facebook
willyb53 ( ) posted Fri, 01 June 2012 at 11:11 PM
I dont do animations, but I think this would be your best bet
Bill
JohnDoe641 ( ) posted Sat, 02 June 2012 at 12:40 AM
Perhaps tuning on collision detection would work, though it's never been absolutely perfect when I've used it.
heddheld ( ) posted Sat, 02 June 2012 at 2:21 AM
I would use the graph editor to do that
fleshoff ( ) posted Sat, 02 June 2012 at 9:08 AM
"I would use the graph editor to do that"
Can you tell me more what you mean?
www.insectula.com
Facebook
MistyLaraCarrara ( ) posted Sat, 02 June 2012 at 10:42 AM
omg, the problems, yes.  staircases, uneven ground terrains.  fists of fury physical contact
heddheld ( ) posted Sat, 02 June 2012 at 11:36 AM
if you click the key on the animation bit then click the wiggy red line in the animation window that opens you get to the graph editor, easy (but tedious) to adjust the position of your object there, if its a doll an your using a bvh and its that which is making it "go underground" its prob a lot easier to adjust the bvh file(is a couple of free bvh editors )
fleshoff ( ) posted Sun, 03 June 2012 at 1:06 AM
Thank you so much
www.insectula.com
Facebook
