Thu, Jan 9, 12:48 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
Carrara Free Stuff here.
Subject: Applying shader to multiple objects
johnj ( ) posted Tue, 28 August 2001 at 8:33 PM · edited Wed, 08 January 2025 at 8:25 PM
I have tried to find a way to apply and/ or change a shader for multiple objects. If you select them all and group them, you cannot drop a texture on the whole group. If you simply select a set of objects (without grouping them) you also cannot just apply one shader to all of them. Help? Another puzzler, why is it that you can only replicate ( and use a pattern to position) in the vertex modeler? The assembly room could use this functionality. John Jacobson
MarkBremmer ( ) posted Wed, 29 August 2001 at 3:03 PM
Hi John, What you are describing is a work flow issue. As each object is completed, it's best to immediately assign it a shader. (While it would be nice to group objects and drag a shader onto the group, Carrara obviously doesn't allow that.) However, once you have assigned a shader to all of the objects, any subsequent changes you make to the shader will automatically update any object that it is used on. So how do you assign a shader to a bunch of objects now? If they are so close together that dragging a shader onto them is a problem, try using the property tray. There is a pull down menu that allows you to select any object in a scene by name. Then immediatly below that is another pull down menu that allows you to select a shader for the object. It still might take a little time but is workable though. I'm not clear on your replicate issue. What do you mean by using a pattern? Mark
johnj ( ) posted Wed, 29 August 2001 at 7:38 PM
Using replicate in the vertex modeler, you can create multiple identical objects with an offset in one or many directions. This way you can create a set of objects without needing to position each one.
MarkBremmer ( ) posted Wed, 29 August 2001 at 9:39 PM
Yep, it does. (Command/Apple-D if on a Mac)
alliagedesign ( ) posted Mon, 03 September 2001 at 2:00 PM
Good Morning I am french, Sorry i don't understand very well how to do it could you explain it another time or better in french ? thanks all
litst ( ) posted Tue, 04 September 2001 at 2:55 PM
Hi all, When i want to add the same shader to several objects in a group, i usually jump in the group, grab the shader to one object and use the eyedrop tool to apply the shader to the other objects . This is the fastest solution i've found . But i'm still often frustrated to be unable to apply the shader simply to the group . J-J, je t'ai expliqucette technique sur Yahoo donc je traduis pas . Mark proposait d'afficher les propri de chaque objet . Puis, avec le menu doulant (une petite flhe bleu vers le bas) tu choisis le matiau dans la liste . C'est pratique si les objects sont les uns sur les autres . litst
alliagedesign ( ) posted Tue, 04 September 2001 at 4:15 PM
Ok merci pour la traduction, ta technique est la meilleur pour l'instant, j'en ai parlEovia qui se penche sur la question ; ils me tiendront au courant et je vous ferais suivre l'info. JJ
