Tue, Dec 3, 6:56 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 03 5:49 pm)
Subject: Cloth Room Crash'n
dragonsfirenh ( ) posted Fri, 15 June 2012 at 8:25 PM · edited Tue, 03 December 2024 at 6:50 PM
I have had nothing but bad luck cross three versions of poser, and two different computers with cloth room. I am now using 2012 Pro on a brand new system with a fresh install and darnit it still does not work. What happens is any dynamic item with any char will just sit and freeze the system and never go any place when I hit sim. Now if I do not have colisions on then no issue but the cloth does not work very well that way :) If I take a cube, very basic item and put a simple cloth object like a square cloth and use colisions it still locks up, even only one drape frame.
 As you see I have tried to make it as simple as I can yet nothing seems to work.
Has anyone seen this before and any clue how to fix?
Windows 7 64 and Poser Pro 2012 64, is it the 64 bit progs?
ArtByMel ( ) posted Fri, 15 June 2012 at 8:28 PM
Do you have Poser installed outside of the programs directory?
My store here at Renderosity.
Art By Mel
dragonsfirenh ( ) posted Fri, 15 June 2012 at 8:33 PM
Yes it is on it's own drive.
dragonsfirenh ( ) posted Fri, 15 June 2012 at 9:04 PM
Can you have Poser in the Programs Dir and the content on another drive?
moriador ( ) posted Fri, 15 June 2012 at 9:53 PM
Have you installed SR 2?
I thought there were bugs with drape in Poser Pro 2012, and that they were addressed in the SR.  But it's a distant memory, so I could easily be wrong.
dragonsfirenh ( ) posted Fri, 15 June 2012 at 10:49 PM
Seems to work now in the prog dir as long as I do not use drape with sr2.1
moriador ( ) posted Sat, 16 June 2012 at 1:26 AM · edited Sat, 16 June 2012 at 1:27 AM
Ah, so drape is still a problem?
I did have some sims I had to redo in Poser Pro 2010 without a problem that wouldn't sim in 2012, but I really thought the SR fixed them. Oh, well.
