Never mind. I see it is 2.1, even though the update page just says SR2. They could be a bit clearer and more consistent.
______________
I just got the notice when I opened 2012 about five minutes ago. Guess I'll go check it out.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
I got that update and after running it it says version 9.0.2.21561
Laurie: I've also thought the same thing (including again today) regarding the desirability of putting dates on service releases.
When I installed I got a lot of errors on the DLLs (wouldn't delete). I had to rename a bunch manually. Not sure what that was about... never needed to do that before.
______________
Well, yes. Rather than simply SR2, it should read SR2.1, released x date. Installing this update should give you version x.x.xxxxxxx in your About Poser information.
Or something like that. The point is that it should be immediately obvious whether you already have the update.
An informal changelog providing a select list of improvements would be kind of nice too.
______________
Quote - 9.0.2.21492 had an issue with updating 32-bit only Windows Pro installations. That's fixed in 9.0.2.21561.
So is this what it is for sure? I just got an update notice for P9 startup, that I did not get when I started yesterday?
I run 64-bit, so I suppose if the above is true, this is not needed, but will this notice keep popping up? If so I may upgrade to avoid the nag.
If you receive a notice you're not updated to SR2.1 yet (9.0.2.21492+) and should update. If you have 9.0.2.21492 or newer installed, you won't be prompted.
Inability to update DLLs usually means that Poser, Queue Manager or FFRender aren't entirely shut down. So the updater can't swap out DLLs because they're still in use.
Okay, this is odd.
The Poser update page is not showing any recent updates (since SR2): http://poser.smithmicro.com/updates.html
But when I booted up Poser (Pro 2012), I just got a notice that an update was available. I had the choice to say OK or to go get it; I chose the former because I prefer to visit the web site independently. But as you can see above... there is no update... unless I'm missing something.
I'm showing version # 9.0.2.21214
______________
