Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
There are lots of variations of V4, some of them have additional material zones. If EZSkin encounters such a zone, it will give a warning and the original material is kept for that zone. This is normal behaviour and everyone oftens sees these messages. If you press OK, the other material zones will be modified by EZSkin.
If you look in the material room, advanced section you will see the new materials. If you have the render options correct and you render, you should see a difference.
If the materials have not been changed, there is something else wrong.
maybe an obvious question...but.. you are pressing the 'do it, convert all materials' button .. correct? not just pressing the 'draft/preview/final' buttons. This message pops up when there is not an entry in the xml file for a material that is in the figure. I cant recall if v4 has a default material but if it does it shouldn't do anything at all, so the fact that ezskin cant convert it shouldnt matter
I think i am kinda confused here...what exactly does EZSkin do?...i thaught that it completely changed the texture set of the default figure...but it sems that it only applies SSS shaders to the default skin texture...?....?...?...
because i see no skin texture sets in the script self to choose from...
I seem to mainly get that error message when I've ticked the "other materials" box and there is a material in a prop or figure (e.g. hair or jewellery) parented to the figure maybe that isn't recognised... or perhaps the texture set I've applied has extra material zones in it and those have been added to the figure.
Also had it when I've accidentally applied an inappropriate material set to a figure, adding the material zones from an unrelated prop, and have then gone to run EZSkin.
In all these cases it should be okay to simply tick the ignore errors box... and thereby avoid okay'ing lots of erroneous messages.
Cheers
I am tryinpg to apply Snarlys EZSkin but i am getting this pop up...what isa the problem here and how can i solve this?...
thanks for viewing.
POSER PRO 2012 64BIT
WINDOWS 7 64BIT
