Mon, Feb 3, 12:06 PM CST
Subject: A couple of questions re installing V4/M4 morphs & V4-WM
barrowlass ( ) posted Mon, 25 June 2012 at 6:20 AM · edited Sun, 02 February 2025 at 2:26 PM
Hi - I've successfully installed DAZ M4 and V4 bases (not without a bit of fiddling about as DAZ - as usual had created a nested Runtime within the Runtime in users/Poser 9 content.  However, the morphs packages resolutely refuse to install either to there or to the P9 Runtime in x86 (I'm running W7 and am aware of the problem there).
Also I'd like to install the WM for V4 - it looks wonderful but not sure how to do it.  I've only had P9 a few days, though I've been playing with Poser since P4 and still have P7 and P8.
Any advice and tips would be very much appreciated.  God I feel like a n00b! lol
My aspiration: to make a decent Poser Render I'm an Oldie, a goldie, but not a miracle worker :-)
Gallery
Freebies
Music Vids
wimvdb ( ) posted Mon, 25 June 2012 at 6:48 AM
What is the error you are getting?
There are several possible reason for not installing the morphs, the error would help to indentify which one it is
barrowlass ( ) posted Mon, 25 June 2012 at 6:55 AM
The installer insists they should be installed where the poser executable is. I'm away from my PC atm but will try to post a s/s later
Gallery
Freebies
Music Vids
wimvdb ( ) posted Mon, 25 June 2012 at 7:01 AM
Ok, the installer checks for a poser.exe in the folder where you want to install the morph pack. I think it also checks for an installed V4.
Fooling the installer is easy: Just create a file with the name poser.exe (can be any file, make sure it has not another extension behind it) in the runtime where you want to install the morph pack (don't forget to initialize afterwards)
barrowlass ( ) posted Mon, 25 June 2012 at 8:54 AM
Thanks - I did wonder about doing that. I'll give it a go. I wasn't sure what with the W7/P9 security set up
Gallery
Freebies
Music Vids
wimvdb ( ) posted Mon, 25 June 2012 at 9:00 AM
You said you installed V4 in the in the users folder (not in Programs), so there should be no security issues.
barrowlass ( ) posted Mon, 25 June 2012 at 9:15 AM
I know but installing to users rather than program files seems to put DAZ into a flip ;)
Gallery
Freebies
Music Vids
wimvdb ( ) posted Mon, 25 June 2012 at 9:28 AM
DAZ installers for V4 and its addons are very old. There were never updated to comply with Windows Vista, Windows 7 or even PoserPro. Installing V4 into Program Files will bring you a lot of troubles.
I still have my Poser 5 installation. I never use P5 anymore, but I contains my main library and after every Poser update I added the P5 runtime as an external library. It has the big advantage that an old installer finds the P5 runtime and installs it there and I can use it from any version of Poser
barrowlass ( ) posted Mon, 25 June 2012 at 9:42 AM
I might install P8 again and do that - just install the DAZ figures there and add them.  I created a text file with the name 'poser.exe' no other extension behind it.  Placed it in the Poser 9 content Runtime.  Daz wouldn't play. Gah!
Gallery
Freebies
Music Vids
moriador ( ) posted Mon, 25 June 2012 at 11:42 AM
Quote - I might install P8 again and do that - just install the DAZ figures there and add them.  I created a text file with the name 'poser.exe' no other extension behind it.  Placed it in the Poser 9 content Runtime.  Daz wouldn't play. Gah!
You can always grab a copy of the actual poser.exe and drop it into your content folder if, for some reason, the fake file isn't working.  Then delete it after you've installed your stuff.
barrowlass ( ) posted Mon, 25 June 2012 at 12:19 PM
I've managed to do the morphs (by keeping the nested DAZ folder) now am figuring out the V4 WM installation :)
Gallery
Freebies
Music Vids
barrowlass ( ) posted Mon, 25 June 2012 at 1:11 PM
Ack! I re-run P9 and loaded up V4 and morphs. Messages that the files can't be found. Will have another go tomorrow
Gallery
Freebies
Music Vids
hborre ( ) posted Mon, 25 June 2012 at 1:32 PM
Online Now!
V4 and the morphs must be in the same runtime regardless whether the folder is external or not.
barrowlass ( ) posted Mon, 25 June 2012 at 1:35 PM
Yes I know but alas DAZ doesn't. The installer tells me all's OK (and I extract to the proper Runtime) - anyway, I'm starting over with a reinstall of P9. I won't let DAZ beat me (even though its illogical where Poser's concerned)
Gallery
Freebies
Music Vids
barrowlass ( ) posted Mon, 25 June 2012 at 5:31 PM
Still messy head-desk-bang
Gallery
Freebies
Music Vids
jestmart ( ) posted Mon, 25 June 2012 at 10:31 PM
Create a new folder for V4, M4 and their morphs.  Choose the DAZ Studio install option instead of the Poser option.  It installs the same files it just avoids the Poser.exe search.  Point the installer to newly created folder.  Point Poser to the folder and you should be good to go.  I feel it is best to have DAZ's Gen 4 figures in their own folder as it is sometimes necessary to rerun the initialize bat files.
barrowlass ( ) posted Tue, 26 June 2012 at 2:29 AM
Thanks I'll give it a go. I feel such an idiot as I've been using Poser for years. Daz files always complicated to install. In previous versions of Windows/Poser I'm sure I created an external Runtime.
Gallery
Freebies
Music Vids
barrowlass ( ) posted Tue, 26 June 2012 at 5:13 AM
Fabulous! It worked.  I now have a 'Daz People' folder on my external HDD for M4/V4 and morphs.  Will do same re hair/clothes.  Now to figure out the V4 WM thingy :) Thanks for all the help everyone - much appreciated!
Gallery
Freebies
Music Vids
