Thu, Jan 23, 2:35 PM CST
Subject: Looking for this vintage style bather
Zev0 ( ) posted Fri, 06 July 2012 at 4:28 AM · edited Wed, 22 January 2025 at 7:21 PM
I need this type of bather or clothing. Must be the identical style. Any available?
My Renderosity Store
Zev0 ( ) posted Fri, 06 July 2012 at 4:29 AM
more ref...
Gremalkyn ( ) posted Fri, 06 July 2012 at 4:57 AM · edited Fri, 06 July 2012 at 4:58 AM
That is a top over a bottom, so maybe a pull over shirt.  If not, can you use this?
http://www.renderosity.com/mod/bcs/retrogirl/88233
Zev0 ( ) posted Fri, 06 July 2012 at 5:07 AM
ah ur right. I thought it was one piece... cool. Now to find that shirt
Gremalkyn ( ) posted Fri, 06 July 2012 at 5:12 AM · edited Fri, 06 July 2012 at 5:16 AM
"Tankini" is, I think, what you want - according to Ujena (my go-to for swimwear ideas).
http://www.ujena.com/xbikini-details.php?cid=185&pid=A328&st=A328
Notice the cut of the top?  Hard to see with the matching color and short on the hem line, but I think that is the cut in your first pic.  Now, to find a Poser version . . . :p
This swimdress is a bit long.
http://www.ujena.com/xbikini-details.php?vv=237&mm=A313
Anyway, more terms for searching. :)
Zev0 ( ) posted Fri, 06 July 2012 at 5:42 AM
Its cool. I already just took a shirt into Zbrush and modified it. Thanks for your help.
pitklad ( ) posted Fri, 06 July 2012 at 5:47 AM
Judy has one on her default garderobe
My FreeStuff
Zev0 ( ) posted Fri, 06 July 2012 at 6:12 AM
The outfit doesnt curve on the thigh. Its horizontal. So a tanktop extended lower is what I used. It must have a straight edge.
lesbentley ( ) posted Fri, 06 July 2012 at 6:53 AM
Perhaps a catsuit with a transparency map?
Zev0 ( ) posted Fri, 06 July 2012 at 7:22 AM · edited Fri, 06 July 2012 at 7:22 AM
Problem with a catsuit is that it shrink wraps to the body around the hip area. It must straight across both thighs. A modified tank top did the trick. Just extended the lengh.
KristiS ( ) posted Fri, 06 July 2012 at 10:28 AM
Not sure if this will work for you or not, but thought I would share it with you just in case:
http://www.renderosity.com/mod/bcs/rg-swimsuit-t1-for-v4a4g4elite/71114
Kristi
Community Relations Specialist
This is your life - your platform - your stage - your story
gloomy007 ( ) posted Fri, 06 July 2012 at 12:00 PM
Propschick has Beachy Keen , maybe you can make breast part invisable and replace it with a halter top from SEA by fabiana ;)
DAZ Studio Coordinator.
You can contact me in english.
Jij kan mij berichtje sturen in Nederlands,
Mozesz sie ze mna skontaktowac po Polsku
Lully ( ) posted Fri, 06 July 2012 at 12:14 PM
I get a pretty good result from this outfit, just hide the fur bit by making it invisible in the mat room and alter the rest of the mat zones to suit
http://www.evilinnocence.com/xmas-08-for-v4.html
Tools:- Win10, Dell XPS8900, ZBrush, Marvelous Designer 11, Hex 2, PSP8. PSP 2019 Ultimate, DAZ Studio, Affinity Photo, Affinity Designer, Filterforge 11, flowscape,  Classic UVMapper, and several headache tablets.
Zev0 ( ) posted Fri, 06 July 2012 at 2:59 PM
Kristis and Lully those are perfect. Since Lully's is the free option I'll go with that:) Gloomy007, the outfit MUST have straps so unfortunately your choice is not an option. The bottom section of that set is however is perfect. Thank you all:)
KristiS ( ) posted Fri, 06 July 2012 at 4:07 PM · edited Fri, 06 July 2012 at 4:08 PM
You are very welcome...so glad you found something you can use😄
Have a fantasic weekend!!
Kristi
Acadia ( ) posted Fri, 06 July 2012 at 8:38 PM
Acadia ( ) posted Fri, 06 July 2012 at 8:54 PM · edited Fri, 06 July 2012 at 8:55 PM
Acadia ( ) posted Fri, 06 July 2012 at 9:01 PM
Here are some textures for Roogna's swimsuit listed above
http://www.sharecg.com/v/34540/browse/11/Poser/TD-RGSwimWear-T1-Textures
Zev0 ( ) posted Sat, 07 July 2012 at 6:22 AM · edited Sat, 07 July 2012 at 6:26 AM
:) downlaoded them all. Thanks Acadia:) Not going to use retro girl though. The bottom shape is incorrect. Lully's example was the closest to what I was looking for.
