Thu, Jan 9, 4:41 PM CST
Subject: .CR2 and .OBJ files
josue_light ( ) posted Mon, 09 July 2012 at 10:35 AM · edited Thu, 09 January 2025 at 7:17 AM
Hello, I've been trying to model my own clothing for Victoria 4. I have an exported .obj file of a shirt I made in Marvelous Designer, and I'm trying to set it up as a character / .cr2 file in Poser so I can use the Morphing Clothes program to add Victoria's morphs to the outfit.
How does one create a .cr2 file of a .obj file? How does one create a Clothes Poser Figure with just an .obj? Or am I going in the right direction?
Thanks!
LaurieA ( ) posted Mon, 09 July 2012 at 11:11 AM · edited Mon, 09 July 2012 at 11:15 AM
Well, you'll need to group it. And good luck doing that with the delaunay triangles Marvelous Designer exports ;). You're better off using it as dynamic rather than a conformer. If you want to use it as a conformer you'll probably have to retopologize it. In the cloth room (dynamics) those triangle arrangements work in your favor ;).
.obj is the correct format to use, in both cases (dynamic or conformer).
PhilC ( ) posted Mon, 09 July 2012 at 11:44 AM
OBJ2CR2 will take your OBJ file and very quickly and painlessly make it into a Poser figure that may then be conformed to V4.
http://www.philc.net/OBJ2CR2_page1.php
If you are using a later version of Poser (8 onwards) you will be able to use the included Wardrobe Wizard to add morphs to that clothing to match morphs in the figure.
josue_light ( ) posted Mon, 09 July 2012 at 9:31 PM
I purchased OBJ2CR2, and everything worked. Thanks a bunch you guys! :3
EnglishBob ( ) posted Tue, 10 July 2012 at 4:53 AM · edited Tue, 10 July 2012 at 4:55 AM
Attached Link: http://www.philc.net/forum/viewtopic.php?t=2332
OBJ2CR2 rocks. :-)
I wouldn't worry too much about the triangulation. In my experience, grouping accuracy isn't all that important (and OBJ2CR2 takes advantage of this); however if it's assymmetrical it can increase your workload when making morphs.
josue_light ( ) posted Thu, 12 July 2012 at 10:23 AM
Thanks for the tip. x3
EnglishBob ( ) posted Thu, 12 July 2012 at 10:35 AM
Let us see some pictures when it's done. :-)
